guys, i have good news for firmware
xsaw
Postby xsaw » Wed Dec 05, 2012 12:39 am
the factory is release a new version firmware today. once i got it will upload to here
also xbmc update version is very good for UG007
http://xbmc.org/natethomas/2012/12/02/x ... h-android/
Kvens
Re: guys, i have good news for firmware
Postby Kvens » Thu Dec 06, 2012 5:42 pm
The build on my UG007 is RK30_ANDROID4.1.1-SDK-v1.00.1015.
What is your version?
xsaw
Postby xsaw » Fri Dec 07, 2012 4:52 am
i just got it from factory..Please do not upgrade if you UG007 is working fine
i know some guys upgrade with wrong firmware it cause the wifi not working. please try this out. and report here what's new.. i'm on the way back.. after i will test it myself.
1.copy update.zip to TF card
2.insert TF card to UG007. system will remind you update system. select yes
3.after 10 seconds the system will reboot and proceed update progress. DO NOT remove TF card and power OFF while the system upgrading.
4.upgrade need couple minutes. if not successful please repeat step 2-4.
https://www.dropbox.com/s/kug6lsoo6vxnq ... _64083.zip
xsaw
Postby xsaw » Fri Dec 07, 2012 9:25 am
i had test on my UG007, it seems they give me wrong version.
the version is: RK30_ANDROID4.1.1-SDK-V1.00.1015
RK30sdk-eng4.1.1 jro03h eng.ant 20121201.102911 test-keys
i don't remember is all the same. but for these guy upgrade wrong version firmware is helping..
xsaw
Postby xsaw » Fri Dec 07, 2012 9:27 am
the wifi & BT headphone is working fine.
pacopa21
Postby pacopa21 » Sun Dec 09, 2012 7:21 pm
hi guys, I've done the procedure to copy the zip in TFcard but does nothing. Could you explain the procedure, since as stated above does not detect anything. sorry, translated with google translator.
ok. I've got. was renamed as update zip. have to rename the zip file. I will test
fred_yu_job
Postby fred_yu_job » Wed Dec 12, 2012 7:34 pm
Is there any improvement in this firmware?
xsaw
Postby xsaw » Wed Dec 12, 2012 9:48 pm
i don't see any update at all. if you stick working fine don't update it.
cardfire
Postby cardfire » Thu Dec 27, 2012 8:58 pm
Has anyone successfully flashed with this firmware update, and lived to tell about it?
k4nz4k1g4w4
Postby k4nz4k1g4w4 » Mon Feb 11, 2013 7:48 pm
I'm looking for (original) firmware for the UG007 bluetooth.
Anyone know where I can get it?
k4
seph67
Postby seph67 » Tue Feb 19, 2013 7:11 am
Is there a way to reflash a bricked unit with the stock firmware ?
Regards
