imito MX2 freeze with WiFi enabled
fantasmicmickey
Postby fantasmicmickey » Mon Dec 17, 2012 8:02 pm
I have a freezing problem with my MX2 running build iMito_RK3066_V411_121129. I turn off Wi-Fi and can run for hours without freezing. Once I enable Wi-Fi it would freeze within 15-30 minutes while browsing or doing anything network related.
The MX2 with Wi-Fi off will also freeze when running AnTuTu Benchmark on the OpenGL ES1.1 test every time.
Mitchell4you.
Re: imito MX2 freeze with WiFi enabled
Postby Mitchell4you. » Mon Dec 17, 2012 8:36 pm
You answered your own question : AnTuTu needs to be online to work
fantasmicmickey
Postby fantasmicmickey » Tue Dec 18, 2012 2:22 pm
AnTuTu only needs to be online when posting/comparing results. My MX2 completely locks up when running one of the tests. My mouse pointer does not move and it doesn't respond to usb keyboard input. I can't do anything except for pulling the power and reset.
atlr
Postby atlr » Fri Dec 21, 2012 2:45 am
I received an MX2 with blue case (don't know the color of the circuit board) on 12/17 which also locks up when wifi is enabled. Zhangyan shipped it to me on 11/30. I ordered the MX from in4dealz on 11/24.
lexan76
Re: Sv: imito MX2 freeze with WiFi enabled
Postby lexan76 » Sun Dec 30, 2012 5:39 am
My mx1 also seems to freeze or deep sleep. I'm always on wifi and bt, and only way to get back is to pull the power.
Fredrik
Skickat från min Transformer TF101 via Tapatalk 2
minimuscle
Postby minimuscle » Sun Dec 30, 2012 3:41 pm
I have one that freezes randomly
Return to “MX2”
