How about Kimdecent T21 w/ Nufront CPU for $49
seankps
Postby seankps » Thu Nov 29, 2012 4:17 pm
So I've been seeing this one around
Kimdecent T21 stick for $49
and it seems pretty decent in terms of both price and specs.
Anyone tried it? Feedback?
Also, how about we get a thread for these Nufront / NS115 CPU sticks?
thanks
SuhiJr
Re: How about Kimdecent T21 w/ Nufront CPU for $49
Postby SuhiJr » Thu Nov 29, 2012 6:51 pm
I think that GPU has only two core Mali400
Sent from my HUAWEI U8815 using Tapatalk 2
seankps
Postby seankps » Fri Nov 30, 2012 10:53 am
SuhiJr wrote:I think that GPU has only two core Mali400
Well yeah, that is part of it's specs.
csgabe
Postby csgabe » Fri Nov 30, 2012 11:30 am
There is a review in Spanish of the T21 stick:
http://androidpc.es/blog/2012/11/28/ana ... ont-ns115/
csgabe
Postby csgabe » Thu Dec 06, 2012 4:51 pm
Kimdecent T21 kernel config file:
t21config.zip
CoolkcaH
Postby CoolkcaH » Fri Feb 15, 2013 10:34 pm
I bought an Equiso Pro, a NS115 android stick manufactured by Uptek very similar to Kimdecent T21, but also has bluetooth.
http://clare627.en.ec21.com/Dual_Core_H ... 38848.html
It comes with a 3.0.0 kernel (lajoin kernel from uptek).
I would love to use usb audio kernel modules for it, but I can't find pre-compiled for this kernel and I don't have the kernel sources....
Do you think it is possible with your configuration? How can you use the config without the kernel sources?
csgabe
Postby csgabe » Sat Feb 16, 2013 2:17 am
You have to ask from Equiso the GPL kernel sources.
CoolkcaH
Postby CoolkcaH » Tue Feb 19, 2013 9:40 am
I obtained the kernel sources for the Uptek manufactured android stick with Nufront NS115 SoC, also available as the Equiso Pro.
https://docs.google.com/file/d/0By6VL5JBm65uR3F2Q1JpSUtneEE/edit
This might work on the Kimdecent T21, but the uptek is a different device with bluetooth and the kernel configurations may be different.
I will try to use it to compile usb audio modules.
Return to “Android TV Sticks”
