Official Android 4.4 KitKat Firmware For RK3188T TV BOX
geekbuying
Postby geekbuying » Mon Mar 31, 2014 11:56 pm
HI guys:
Rockchip release the official android 4.4 firmware for their tv box and tv stickes, today, we just get this firmware, it is special for the tv box which use AP6210 wifi module. If your tv box/sticks don’t use this module, please don’t flash, you will lose your wifi and bluetooth, please note!
We have tried this on MK908II and MK809III with AP6210, both can work well, please help to test more models, and report back.
The official firmware has fixed some bugs in the beta android 4.4 firmware, please flash and check.
One problem i find in this firmware is there is NO Google apps ( play store, gmail, google play service) preinstalled, It’s really sucks, don’t know why rockchip remove those in this official update, but i know we can add this by ourselves. I still tried to figure out how to install that by myself, if you know how to fix that, please leave message here. ok, here we go:
Firmware Download Link
password is geekbuying.com
ROM is not rooted, and you should root by yourself. Here i recommend you a easy root method, download the root tool here:
http://www.mgyun.com/en/GetVRoot
Run and install this tool in your PC and go to your tv box setting, and open the “USB Debug” setting, and just click Get root button, this tool will help you to get root. easily.
ROM is still base on 720p. and we are working with the developer,and will release the 1080p version soon.
The total performance of Android 4.4 Kitkat has been improved a lot than the Jelly Bean Android 4.2. It has less boot time, and system is much steady and fast.
Enjoy!
Screenshot:
Some hot selling TV BOX/Sticks with AP6210 recommended:
1. Tronsmart MK908II
2. CX-919
3. MK809III
4. MK918
Source from: http://bit.ly/1giWLIB
pgy
Re: Official Android 4.4 KitKat Firmware For RK3188T TV BOX
Postby pgy » Fri May 16, 2014 5:56 am
This image works great on RK3188T based device mk809iv. It boots fast to the desktop. I can choose which home application to use among the two choices.
However, I am not sure what's wifi hardware of this stick, so it lost wifi connection. Another issue is the sound is also lost.
Any idea what image should be used for this kind of device?
Return to “Android TV Sticks”
