if i would have to buy today
eskro32
Postby eskro32 » Thu Jan 31, 2013 11:47 pm
Hi guys, i wonder, if you had to buy an android tv stick today,
which model would it be and why?
thanks!
lefizz
Re: if i would have to buy today
Postby lefizz » Fri Feb 01, 2013 2:38 am
Well i bought an MX 2 and a Gk802 a couple of weeks ago. They haven't arrived yet. The MX because they seem to get well reviewed and have the rk3066 which seems like the best choice for dual core. The Gk cos i wanted something that was likely to get s lot of Dev work done to it. I know its a bit rough at the moment but i think being the first quad core a lot of people have and will be interested in it so it will be well supported in the future.
That's my thinking
Sent from my ZP900 using Tapatalk 2
andrewsuu
Postby andrewsuu » Mon Feb 25, 2013 2:17 am
I'm looking for help to see if other units have the same issue before I go out and buy
eskro32
Postby eskro32 » Mon Feb 25, 2013 9:58 am
which issue?
Kainiac08
Postby Kainiac08 » Tue Feb 26, 2013 3:24 pm
I purchased the MK808 from Amazon and I'm sending it back. The WiFi just does not work great and I am not going to attempt any of the suggested hardware fixes as I am NOT skilled in that.
I'm quite disappointed. However, I would like to replace it. Any suggestions? I am looking at the iMoto MX1.
eskro32
Postby eskro32 » Wed Feb 27, 2013 9:18 am
uHOST2 seems like the most recommended model. stable wifi and frequent firmware updates and good support.
kurjak
Postby kurjak » Mon Apr 01, 2013 5:09 am
Does any of these sticks/stb-s support XBMC hardware decoding without external player?
eskro32
Postby eskro32 » Tue Apr 02, 2013 2:34 am
nope, none of them.
only the pivos xios supports xbmc hardware accel
asifadeel
Postby asifadeel » Fri Dec 27, 2013 2:30 am
I'm developing an application with Open GL ES2 that I plan to run on units like the MK808. I'm having trouble to get the animations perfectly smooth. The animation hack every 1-2 sec. Not a lot, but enough to be irritating. I don't think the problem is with graphics performance because the frame rate is good when I measure. I have also tested with other Open GL applications to be sure the error is not in my own code.
I have tested on MK808 and MK802 and both have this issue. My phone, the quite old Nexus One and tablet, Nexus 10, does not.
I'm looking for help to see if other units have the same issue before I go out and buy it. I have tested with the application AndEngineExamples and example Modifier & Animations -> Using EasyFunctions -> EaseLinear, it shows the problem quite good.
Julyding
Postby Julyding » Tue Jan 14, 2014 4:51 am
well, for this question, recommend a nice store to you:
http://www.aliexpress.com/store/613484
all kinds of mini pcs and tv boxes, and CS918s now is hot selling.
have a nice day!
Return to “Android TV Sticks”
