Allwinner A80 8Core TV Box, DDR3 4GB , Nand Flash 32GB
kavera
Postby kavera » Wed Dec 24, 2014 12:27 am
http://www.aliexpress.com/store/product/CS-Q8-Qcta-Core-Android-4-4-TV-Box-Mini-PC-A80-4GB-DDR3-32GB-Support/511353_32242945331.html
Only 219$
Specification:
Hardware Spec:
Operation System
Android 4.4
Language
Chinese,English... Multi-Language support
CPU
(A80)Ouad-Core ARM Cortex A15/A7
GPU
64-Core PowerVR G6230
SDRAM
DDR3 4GB
Flash
32GB
Network
IEEE 802.11 a/b/g/n/ac
WIFI Module
AP6330 / AP6335
The extended storage
SD Card, up to 64GB
Power Supply
DC12V/2A 5.5mm DC-in
Interface:
HDMI Output
1*HDMI1.4
USB Port
2*USB2.0 Host, 1*USB3.0 Host
Data Output
1*SPDIF
Card Readere
1*SD Card slot
AV Out
1*AV Port
Network
1*RJ45 10M/100M/1000M
Power Supply
1*5.5mm DC 12V/2A Power
HDD
1*SATA Port
Media Parameter:
Audio Container
Supports MP3, AAC, WMA, RM, FLAC, Ogg and programmable with 5.1 down-mixing
Audio Out
HDMI Data Output
Video Decoder
Supports *.mkv,*.wmv,*.mpg, *.mpeg, *.dat, *.avi, *.mov, *.iso, *.mp4, *.rm and *.jpg file formats
Video Encoder
H.265 HEVC/ MP L5.0 up to 4Kx2K/30fps
Resolution
Maximum resolution is 4Kx2K
Software Extension
Support Google Play & APK install
DLNA,Miracast Protocol(DLNA,Miracast)
Support DLNA,Miracast Protocol
Remote Control
Remote controller
IM Software
Support Skype/QQ/MSN/GTALK (Depends on APK )
Offic Software
WORD/EXCEL/PDF(Depends on APK install)
Others Parameters:
Operationg Temperature
-10~40degree
Storage Temperature
-20~50degree
Humidity environment
5%-90%(No condensation)
Certification
CCC,CE,FCC,Wi-Fi
Return to “Set Top Boxes”
Users browsing this forum: Bing [Bot] and 1 guest
