Geniatech Android TV Box supports full- featured XBMC
General Discussion of Android TV Products
lily0505
Postby lily0505 » Mon Feb 04, 2013 3:33 am
Q: I want to buy Geniatech box" ATV520 Dual Core CPU 1.2GHz-1.5GHz Google Android 4.1 TV Box 1GB RAM WiFi RJ45 Ethernet HDMI OUT 1080P HD Media Player IPTV set top box" Please let me know clearly will I be able to install XBMC and XBMC will work smooth ?
A: As for the XBMC, It is just an application to install on the box.and there is no problem to install for Genatech Android TV Box, The question is,not because of the Android system. But because of chips determined whether can it run smoothly. Recently, the Geniatech Dual Core ATV520 box is hot selling and of course to install XBMC.
Content is king, and so far Google TV is sorely lacking content. However, with the launch of the famed Xbox Media Center on Android, Google might have a chance in the battle for living rooms.The good news is that the Android version of XBMC should work on a very wide range of devices. XBMC can be launched as an application on your set-top-box Geniatech Android TV Box, or wherever else Android may be found. XBMC is stable and works great there, as well as on various tablets and phones. The Android platform is now officially supported. Having seen the popularity of this open source media center software, and the willingness of some to spend hundreds of dollars on small computers to use it as their set-top-box interface of choice, XBMC brings full-featured APK to Geniatech Android TV Box.
Geniatech has lunched newest dual Core Android TV Box ATV520, What’s unique about this box is based on Android 4.1 and ARM Cortex A9*2 CPU, frequency is 1.2-1.5GHz Smart TV Box, and there for will play full 1080p video using hardware decoding with the XBMC Android App.
For instance you can stream video from YouTube or Netflix, surf the web, or play games. You can also run a pre-release build of the XBMC on Android Box -- a device with similar hardware. The new Android TV Box features a 1.2-1.5GHz, ARM Cortex-A9 *2processor, 802.11b/g/n WiFi, 1GB of RAM and 4GB of storage.
It also features an Ethernet jack, an HDMI port, 2 full-sized USB ports, and an SD card slot. The device ships with an infrared remote control and an HDMI cable.
Out of the box, the device runs Google Android 4.1 software and includes support for the Google Play Store, which makes downloading and installing apps simple.
Return to “General”
