Remote Control For MiniPc Android MK803
General Discussion of Android TV Products
malba
Postby malba » Wed Jan 16, 2013 8:17 am
hello
I have a mk803
You know if there is any app that allows me to remotely access to minipc from another pc.(like netop, dameware o logmein between pcs)?
I searched, and found apps like
Remote desktop web
Airdroid
Lazydroid
But it seems that these applications generate a link of this type (http://192.168.1.4:8999) to put in the browser, this link is the miniPC IP on the local network. And I just want to handle it outside my local network, and this link (http://192.168.1.4:8999) don´t work
And that's the question, if you know any app that allows me to do this.
thank you very much
csgabe
Re: Remote Control For MiniPc Android MK803
Postby csgabe » Wed Jan 16, 2013 11:03 am
If you want to have access from outside you need to open a port(9999) on your router, for details search for port forwarding & use your public ip address(check with http://whatismyip.org/) when connecting.
malba
Postby malba » Wed Jan 16, 2013 2:11 pm
thaks csgabe, i try it later
i think too, enter with remote control in my house´s pc, and then, enter in the minipc from my pc (all crazzy crazzy..)
yerterday, i used Remote desktop web, but its show me a new desktop that has nothing to do with the minipc. i can only access to directory structure. i can not run installed app in minipc
i will try with Airdroid and Lazydroid to see if it happen the same or not
other thing... if i need to open a port... how i asign a fix ip in the minipc?, i don´t see this option or configuration in wireless configuration
thank for all
comatose1978
Postby comatose1978 » Wed Jan 16, 2013 5:47 pm
I use Teamviewer. it works great and is free.
http://www.teamviewer.com/en/index.aspx
malba
Postby malba » Thu Jan 17, 2013 4:24 am
thanks comatose1978
i try it in the weekend, and tell you if all is ok
thanks
malba
Postby malba » Fri Jan 18, 2013 5:08 am
hello
yesterday i found a post thak said that with "remote desktop web", i could access to same features of minipc, but, if i would control android in its desktop, i would need install "remote control add-on".
with this, the desktop of my android is accesible
i need to test better because all of this run under java, and in my pc i don´t have java updated...
thanks
Return to “General”
