How to flash back to stock ROM from Finless 1.5?
netghoster
Postby netghoster » Wed Feb 13, 2013 6:37 pm
Several apps I am using frequently are not very stable on Finless 1.5. How can I flash back to rooted 11/29/12 ROM? I tried to put the update.img in my SD card. It can find the image and started to flash but failed at the end. Probably it is because I reformated for 2G APP space. Please help.
Thanks,
krasnoff
Re: How to flash back to stock ROM from Finless 1.5?
Postby krasnoff » Thu Feb 14, 2013 10:16 am
just put the update.img file (with stock firmware) to the root of the memory card
netghoster
Postby netghoster » Thu Feb 14, 2013 1:05 pm
krasnoff wrote:just put the update.img file (with stock firmware) to the root of the memory card
I tried it. It started to flash then failed after a while. I believe it is because I did a full wipe to get the 2G app space when I flased the Finless 1.5.
MrFX
Postby MrFX » Fri Feb 15, 2013 7:28 am
Hi,
try flash first finless ROM with original partition sizes and after this reflash the original image.
Best regards,
MrFX
netghoster
Postby netghoster » Mon Feb 18, 2013 10:45 am
MrFX wrote:Hi,
Best regards,
MrFX
Successfully flashed back to the rooted 112912 ROM. Thank you for the advice.
