XBMC hardware decoding
miuca
Postby miuca » Sun Nov 25, 2012 4:16 am
Has anyone managed to find XBMC version with hardware decoding for MX1/MK3066/Mali400 ?
I've tried a couple of releases, newer, older, no luck. Even tried the PIVOS version, which has hardware support enabled for those devices, no luck.
reddragon72
Re: XBMC hardware decoding
Postby reddragon72 » Mon Nov 26, 2012 5:51 pm
Nothing yet. There is a "hack" that allows XBMC to send the video's to an external player. You can find that info on xbmcandroid.com
henk_rf
Postby henk_rf » Mon Dec 03, 2012 7:09 pm
Now you can download Frodo beta 2 directly from the XBMC servers and give it a try in your Android device.
At this point, the team is only officially supporting devices with chips that feature NEON. That includes a wide range of devices including most recent high-end smartphone as well as inexpensive TV sticks and Mini PCs with Amlogic AM8726, Allwinner A10, and Rockchip RK3066 processors.
http://liliputing.com/2012/12/xbmc-12-beta-2-media-center-released-for-android-windows-linux-more.html
GoranFilip
Postby GoranFilip » Tue Dec 04, 2012 2:56 am
Hi there,
I instaled beta2 version but except a few bugs improvements it still not supporting our rockchip for hardware decoding...
miuca
Postby miuca » Fri Dec 07, 2012 4:11 am
Same for me. There is no native hardware support in XBMC beta 2 for MX1.
It's a bit confusing, RK3066 is officially supported. Wondering does any other similar device has hardware support?
ApocalypseSticks
Postby ApocalypseSticks » Sat Dec 08, 2012 10:32 am
This guide to enable the MX Player (HW Decoding supported) for the MK808 also works for the MX1.
viewtopic.php?f=6&t=834
miuca
Postby miuca » Mon Dec 17, 2012 1:01 am
I've tried XBMC RC yesterday and as far as I can see there is hardware decoding in place. Finally!!
The only issue now is that I can't stream HD movies over wi-fi from the home NAS, not even 720's. But that was pretty much expected with all the wi-fi issues. Will probably switch to USB to LAN and put a cable there. Hopefully this will be the last step in order to have a fully functional XBMC media center running from MX1.
fl4r3
Postby fl4r3 » Wed Dec 19, 2012 11:45 am
miuca wrote:I've tried XBMC RC yesterday and as far as I can see there is hardware decoding in place. Finally!!
This is not true. I just tried the RC and latest nightly too (18th december). You are playing videos through software decoding. Playing files less than 720p work fine, anything above (including 720p) stutter terribly. I have 1080p videos streaming through wifi from my NAS perfectly with MX player, albeit using a usb wifi dongle for a better connection, so it is still a case of no hardware decoding in XBMC.
miuca
Postby miuca » Fri Dec 21, 2012 12:34 pm
@fl4r3
Yes, you're right. I was wrong, sorry, there is no hardware decoding. Since this is RC, most probably we will not get it for any RK3066 based devices. We're left with using external players.
Return to “MX1”
