MX1 out the box not working
vassie
Postby vassie » Mon Jan 14, 2013 12:33 pm
Hello
I've just got my MX1, I've plugged it into my TV, attached the power but nothing, my TV does not show anythng
The blue LED light is on and I've tried the MX1 in two different TV's but either see the MX1
Ben
lexan76
Re: Sv: MX1 out the box not working
Postby lexan76 » Tue Jan 15, 2013 3:48 am
vassie wrote:Hello
Ben
How are u powering your mx1? Use the charger and not only your TVs USB power.
Skickat från min Transformer TF101 via Tapatalk 2
texudo
Re: MX1 out the box not working
Postby texudo » Tue Jan 15, 2013 5:28 am
vassie wrote:Hello
Ben
Did you change the displaying from HDMI port?
vassie
Postby vassie » Tue Jan 15, 2013 11:58 am
I am using the power supply that came with it
I have tried all four HDMI sockets on one TV and two on another
lexan76
Postby lexan76 » Wed Jan 16, 2013 5:31 am
vassie wrote:I am using the power supply that came with it
Try another power supply and another USB to micro USB cable.
vassie
Postby vassie » Thu Jan 17, 2013 9:07 am
I've tried another micro USB power supply but the LED light did not come on
fr0d0
Postby fr0d0 » Thu Jan 17, 2013 2:59 pm
vassie wrote:I've tried another micro USB power supply but the LED light did not come on
It needs to be 5v and 2amps. I think the MX will work with 1amp. Standard USB plugs are half that @ 400 to 500 milliamps.
vassie
Postby vassie » Thu Jan 17, 2013 4:56 pm
The one I tried is also V5 2A, the LED comes on but nothing happens
fr0d0
Postby fr0d0 » Thu Jan 17, 2013 8:26 pm
vassie wrote:The one I tried is also V5 2A, the LED comes on but nothing happens
Did you try lots of TV's? My first guess would be that your TV is not compatible. You tried changing the input settings on your TV setup right?
vassie
Postby vassie » Fri Jan 18, 2013 7:20 am
I've tried two different TV's, including my Samsung LED 3D TV
fr0d0
Postby fr0d0 » Fri Jan 18, 2013 9:35 am
Did you try directly plugging it in as well as with the HDMI extension?
Wow this is like pulling teeth
franksemi
Postby franksemi » Fri Jan 18, 2013 1:53 pm
Hey, I have same problem,
tried 6 -7 diffent chargers, various usb cables
tried a 2A charer from a tablet, but no diffent..
and diffent tv's with hdmi.. only a weak light on the android tv stick, but no output..
anyone got it to work?
it sais in the manual 5 -> 30 volt.. that sounds a bit strange..
/Frank
trent
Postby trent » Fri Jan 18, 2013 2:11 pm
Most of us who are posting in this forum have working MX1's, yes.
When I got mine I plugged it in and it just worked, right away. It has been running more or less continuously for weeks.
I am beginning to think yours is broken out the box. I would try to get a replacement if I were you.
vassie
Postby vassie » Sat Jan 19, 2013 3:50 pm
I've also tried plugging it directly into the TV, the thing just doesn't work
fr0d0
Postby fr0d0 » Sat Jan 19, 2013 7:15 pm
vassie wrote:I've also tried plugging it directly into the TV, the thing just doesn't work
2 TVs doesn't sound like a very thorough test.
vassie
Postby vassie » Sun Jan 20, 2013 3:38 pm
Thorough test? how many TV do I have to plug it into?!I expect it to work at the first attempt
fr0d0
Postby fr0d0 » Sun Jan 20, 2013 7:45 pm
vassie wrote:
fr0d0 wrote:
vassie wrote:Thorough test? how many TV do I have to plug it into?!I expect it to work at the first attempt
Just one compatible TV. There are different standards of HDMI.
Return to “MX1”
