The First UG007 Mini PC Review is coming
geekbuying
Contact:
Postby geekbuying » Fri Nov 02, 2012 11:31 am
Hi guys:
We just finish a review for the UG007 mini pc. you can check the review in my blog:
http://blog.geekbuying.com/index.php/20 ... ng-review/
and i know you guys must concern about the audio sync and wifi problem, i also mentioned in the review.
Let's talk.
lassegs
Re: The First UG007 Mini PC Review is coming
Postby lassegs » Sat Nov 03, 2012 4:25 am
Here is my main concerns after the test. AnTuTu still shows 1280x672, even though it says 1280x720 in settings. Can you confirm that screen resolution does not work properly? If so, it seems the UG007 suffers from the same image quality problems that the UG802 has.
Thats why im very interested to see the A/V sync test done properly. As I said in the video, you need to hook that thing up to something with speakers, and listen for beeps when the white square in the video flashes.
cuervodroid
Postby cuervodroid » Tue Nov 06, 2012 12:59 am
I would like to know if the resolution issue is fixed too. If this is fixed I most certanly will order one, that was the thing keeping me from ordering a mk808.
Return to “UG007”
