Poor Wifi
firestarter2
Poor Wifi
Postby firestarter2 » Tue Dec 04, 2012 7:00 pm
So it appears the units wifi is poor at a range of 15 feet from the router if its behind the TV I get 20Mb or so. If I use the HDMI port on the side I get 65Mbit at a 15 feet. Wifi is stable though but not usual able through floors which is what I needed. Though movies seem to periodically freeze
Does this device need an antenna fix?
pbishop
Re: Poor Wifi
Postby pbishop » Fri Dec 14, 2012 11:01 pm
I'm not able to get a wireless N signal on my device, although I can get 4 bars of wireless G signal from the same router.
Has anyone else experienced this ? I bought this device to stream 1080 video, and Wireless G isn't up to the task. The spec says it should support 'N'.
I've tried updating the firmware, but no success.
Any ideas ?
juliotunes
Re: Poor Wifi
Postby juliotunes » Mon Jan 21, 2013 8:18 pm
I solved the poor wi-fi reception by putting a ferrite core around the hdmi cable. It worked for my UG007.
fr0d0
Re: Poor Wifi
Postby fr0d0 » Tue Jan 22, 2013 1:55 am
juliotunes wrote:I solved the poor wi-fi reception by putting a ferrite core around the hdmi cable. It worked for my UG007.
Could you explain further please? Show us how?
juliotunes
Re: Poor Wifi
Postby juliotunes » Tue Jan 22, 2013 4:59 pm
You can see a ferrite core and how to install it around a cable in this page:
http://www.canon.fr/Support/Consumer_Pr ... 1&type=faq
My cable is around the ferrite core like the image above
You can buy one from e-bay
http://www.ebay.com/itm/5-New-3-5mm-Sna ... 2572370ebf
fr0d0
Re: Poor Wifi
Postby fr0d0 » Tue Jan 22, 2013 5:04 pm
Great thank you! :)
The first link is bad but I can guess what you mean.
arnold88
Re: Poor Wifi
Postby arnold88 » Fri Feb 15, 2013 2:02 pm
I can see where this would help clear the HDMI signal to the monitor, but not how it would improve Wifi. I opened the UG007 case and there is a very small, square-like antenna connected by wires.
IRON FIST
Re: Poor Wifi
Postby IRON FIST » Sun Mar 24, 2013 8:50 am
If i was you, I would not use WiFi at all, Unless its your only option..
As you all know WiFi is a lot slower than direct cable in the first place in terms of MBPS
and of course there is also the factor of interference, in city and built up areas which pull the signal down at ANY time.
If you want FULL SPEED wired cable,
you could watch the link below and make up your own mind.
http://www.youtube.com/watch?v=LCXvfz41yv8
Iron Fist.
halabut
Re: Poor Wifi
Postby halabut » Sat Jun 08, 2013 11:04 pm
It appears to be an issue with poor ground planes on the PCB. There's a couple of ways around it, I just unstuck the antenna from the cover and moved to outside so it's now a couple of inches from the PCB. Perfect 802.11n reception.
Halabut
Return to “UG007”
