NTFS support
K0mmaT1A
NTFS support
Postby K0mmaT1A » Tue Jan 08, 2013 5:59 pm
I believe it is fairly easy for someone that can compile linux to implement ntfs support on the kernel,
Can someone take a look here?
http://forum.xda-developers.com/showthr ... ?t=1724078
fxpilot
Re: NTFS support
Postby fxpilot » Wed Jan 16, 2013 4:31 pm
deadhp1,
or
Does a anyone know how to add make a update.zip to add in the fuse.ko
its the FUSE filesystem I need, I think so the GK802 so it can read /write ntfs etc.
Thanks
eclsnowman
Re: NTFS support
Postby eclsnowman » Wed Jan 16, 2013 5:39 pm
Why are you spamming the threads by asking the same question in each one. Be patient the guy is on a trip.
Sent from my Galaxy Nexus using Tapatalk 2
Re: NTFS support
Postby deadhp1 » Fri Jan 18, 2013 2:37 pm
Heads up is the update coming soon has NTFS read/write support.
K0mmaT1A
Re: NTFS support
Postby K0mmaT1A » Sun Jan 27, 2013 7:33 am
Installed Paragon's ntfs app with lastest fw 1.65.4 and it's working perfectly write and read, other apps for ntfs had problems writing...
nice work.
https://play.google.com/store/apps/deta ... nter&hl=el
Return to “Development”
