Compile the kernel- A basic howto
Zormax
Re: Compile the kernel- A basic howto
Postby Zormax » Wed Mar 20, 2013 1:16 pm
I have original MK808B, after creation of a kernel - does not work WiFi and Bt
There are ideas?
mustafaupk
Postby mustafaupk » Mon Apr 08, 2013 11:09 pm
How are you guys flashing your custom kernels on your mk808b? I try replacing the kernel in Finless 1.7 ROM and run the flash tool but I don't boot successfully? I'm wondering if my kernel is the problem or the flashing method.
tonikasch
Contact:
Postby tonikasch » Tue Apr 09, 2013 7:50 pm
mustafaupk wrote:How are you guys flashing your custom kernels on your mk808b? I try replacing the kernel in Finless 1.7 ROM and run the flash tool but I don't boot successfully? I'm wondering if my kernel is the problem or the flashing method.
The last working finless ROM is 1.5, the 1.7 is only for mk808
Anyway, you have to replace recovery and, once flashed and booted to Android, issue these commands through a terminal emulator:
su
reboot recovery
You'll have to issue these commands every time your device (re)boots.
MK808 as server, waiting for full Mali-400 support
Minix X7 arriving home mid September to bring it full linux support :)
...Itaca te ha dado el bello viaje. Sin ella, nunca habrías salido...
mvtechnet
Postby mvtechnet » Thu Apr 18, 2013 11:17 am
What sources are you using to download the packages. I get error (not available or no installation client) with the ubuntu 12.04 LTS I386 install
Zormax
Postby Zormax » Thu Apr 18, 2013 11:25 am
mvtechnet wrote:What sources are you using to download the packages. I get error (not available or no installation client) with the ubuntu 12.04 LTS I386 install
use Mint
mvtechnet
Postby mvtechnet » Thu Apr 18, 2013 2:29 pm
Same errors.
Note, selecting 'libsdl1.2-dev' instead of 'libsdl-dev'
Package lib32ncurses5-dev is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
Package lib32z1-dev is not available, but is referred to by another package.
Package ia32-libs is not available, but is referred to by another package.
E: Unable to locate package libwxgtk2.6-dev
E: Couldn't find any package by regex 'libwxgtk2.6-dev'
E: Package 'ia32-libs' has no installation candidate
E: Package 'lib32z1-dev' has no installation candidate
E: Package 'lib32ncurses5-dev' has no installation candidate
manoranjan2050
Postby manoranjan2050 » Wed May 29, 2013 3:09 pm
any one please upload arm-eabi-linaro-4.6.2 toolchain only in mediafire and devhost .... or upload it in github ... my internet too slow to download all github toolchain .......
AntonZappa
Postby AntonZappa » Fri Jun 19, 2015 6:12 am
Hello!
I've flashed kernel and on lcd monitor picture looks like this (picture in attachment).
what i did wrong?
Return to “Development”
