Driver pack for MK808
acqant
Re: Driver pack for MK808
Postby acqant » Fri Jan 11, 2013 3:40 pm
Powered hub no good. I'm beginning to think it's either the wrong driver ( the one I just dl'd from dlink says rtl8712SU ) or it's the RK wifi app on android.
acqant wrote:So I've got a Dlink DWA-131 H/W Ver: A1 -- F/W Ver: 1.21 -- so says the box.
I've insmod r8712u with no errors. Kernel detects the usb and sees the mac address but when I turn the wifi to ON
I get all kinds of errors.
ANDROID_ERROR) ##wife_probe
ANDROID_ERROR) wifi_set_power = 1 ( I've tried it in the otg and direct usb slot ( Not a powered usb hub )
ANDROID_ERROR) wifi_set_carddetect:1
Then rk29 stuff, Dongle Host stuff
ANDROID_ERROR) wifi_get_mac_addr
I'm thinking I'll try a powered usb hub?????
deadhp1 wrote:
binkers wrote:Maybe I could get someone to compile this r8712u driver for me. I've tried to get it to make a module, but have finally given up after several hours of hammering away.
the driver is at http://git.kernel.org/?p=linux/kernel/g ... 7f5cdbc4ef
The driver for the r8712u is also in the kernel source. I built as a module for you.
r8712u.zip
Hope it works.
vrobi wrote:Hi deadhp1
Please can you help to compile mcs7830.ko
Very Thanks
Done!
mcs7830.zip
neoares
Postby neoares » Mon Jan 14, 2013 5:05 am
Hello! I know some people already compiled modules for usbserial suport. I need modules for ftdi and 16u2atmega chips (arduino nano, uno r3 and mega 2560r3 boards). I see a lot of people have problems with that. Can anyone share or compile such ko filems?
Thank you!
P.S. if I anderstand correctly modules can be used in imito mx1,2 ug007 too?
dofin76
Postby dofin76 » Wed Apr 30, 2014 2:23 pm
Sorry for my English, use google translator. Acquired USB LAN adapter http://www.ahappydeal.com/product-47808.html My MK808B, with firmware:
http://www.freaktab.co...ficial-Finless-ROM-2-1
it does not see, windows detects the device as CH9200. The result of searching for the problem solution in Google was required module device with the extension *ko, and to create the right:
1) the kernel sources - here they are https://github.com/ome...k808/tree/rk3x-3.0.36+
2) sources device driver http://gdurl.com/ZRmL/download
3) linux knowledge is not below average
If You have the ability to compile this module, I would be very grateful.
famt
Postby famt » Tue Jul 15, 2014 11:09 am
Dear All,
I am wondering if someone here could help me. I have a USB Wifi D-Link DWA-125 H/W Ver: A2 F/W Ver: 1.40
My internal MK808 Wifi was broked (it does not work even with it internal antenna and I already tested it with a external 7Db). So I really need to use an WIFI Dongle. Where can I find drivers to aforementioned Wifi Adapter, and what should I do set it correctly on my Mk808?
My Mk808 is running Android Version 4.0.4, Kernel version 3.0.8+...
Thanks in advance.
mbrame
Postby mbrame » Sat Mar 28, 2015 6:49 pm
hello please can you compile for me a AX88179_178A .ko for mk808B original.
source driver
http://www.asix.com.tw/FrootAttach/driv ... CE.tar.bz2
merci . :)
vampirex
Postby vampirex » Mon Jul 13, 2015 11:47 am
mbrame wrote:hello please can you compile for me a AX88179_178A .ko for mk808B original.
source driver
merci . :)
Bonjour,
Not sure if this is what your looking for.
But I just purchased a Trendnet USB 3.0 Gigabit Ethernet adapter, and was doing some research on the drivers, since I have some time for it to ship.
AX88179 Linux kernel 3.x/2.6.x Driver
http://www.asix.com.tw/FrootAttach/driver/AX88179_178A_LINUX_DRIVER_v1.14.0_SOURCE.tar.bz2
Android 4.2 Kernel Module
https://sites.google.com/site/vtsozik/linux/ax88179-n900-meego
ax88179_178a.ko
I won't be able to test these, until I receive my device, but I will update this post when i do.
I'm not very knowledgeable when it comes to these things, so please bare with me as I speculate the steps.
I beleive the kernel needs to be rebuild and flashed or you can push the module directly to the device using 'adb'?
Any help or direction would be helpful?
Useful Links?
http://forum.xda-developers.com/showthread.php?t=2073775 (Unpack/Repack Kernel)
http://android.stackexchange.com/questions/13519/how-to-install-kernel-module-for-android (Push Kernel Modules to Device)
