Driver pack for MK808
natxito
Postby natxito » Fri Nov 09, 2012 9:43 am
Hello,
I am using Finless Bob 1.5a ROM in my MK808. Because of WIFI problems, I bought an Ethernet to USB adapter (Logilink UA0025C 10/100 - Módem). It doesn´t work, but I have found the driver in...
https://github.com/omegamoon/rockchip-rk30xx-mk808/tree/master/drivers/net/usb
Mine is Pegasus.
I tried to build pegasus.ko driver file by downloading kernel.img and ndk tools, but I couldn´t get it. My knowlegde in this issue is poor, and I don´t have too much time to make some trials. My computer is Windows 7 OS.
My idea, if someone know how, have time enough and interest, is to build driver packs for MK808 from omegamoon rockchip sourcecode and for that ROM kernel.
I think a lot of people would appreciate it.
Thanks to all in advance for your help.
Re: Driver pack for MK808
Postby deadhp1 » Sat Nov 10, 2012 4:52 pm
I've compiled pegasus.ko for you.
Hopefully it works out.
pangyuliu
Postby pangyuliu » Mon Nov 19, 2012 11:21 am
Hi deadhp1
Can you help to compile asix.ko as well :D
I am stuck with building driver for MK808 :oops:
Thanks a lot.
Postby deadhp1 » Mon Nov 19, 2012 12:03 pm
pangyuliu wrote:Hi deadhp1
Thanks a lot.
I've compiled asix.ko
hope it works for you.
asix.zip
a.alekizoglou
Postby a.alekizoglou » Mon Nov 19, 2012 1:27 pm
Based on a omegamons' rk3066 firmware or even AndrewDB's is there a way I can compile wifi driver only?
I was curious if I can get rtl8192cu and see if this would work with my device rtl8188cus (based on realtek it's the same driver, and in windows it install the sames driver).
gkamas
Postby gkamas » Mon Nov 19, 2012 3:02 pm
Hello,
Is possible to complile also the rt73usb.ko?
Thank you in advance!
yobikap
Postby yobikap » Mon Nov 19, 2012 4:57 pm
a.alekizoglou wrote:Based on a omegamons' rk3066 firmware or even AndrewDB's is there a way I can compile wifi driver only?
See this thread: viewtopic.php?f=66&t=231
binkers
Postby binkers » Mon Nov 19, 2012 8:50 pm
Maybe I could get someone to compile this r8712u driver for me. I've tried to get it to make a module, but have finally given up after several hours of hammering away.
the driver is at http://git.kernel.org/?p=linux/kernel/g ... 7f5cdbc4ef
pangyuliu
Postby pangyuliu » Tue Nov 20, 2012 10:00 am
The finless 1.5a does support Apple usb ethernet device which chipset is AX88772A ...
But my device which is AX8872B seems not working ... :cry:
[ 5392.363021] usb 2-1: new high speed USB device number 4 using usb20_host
[ 5392.586689] usb 2-1: New USB device found, idVendor=0b95, idProduct=772b
[ 5392.593632] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5392.600846] usb 2-1: Product: AX88772B
[ 5392.604701] usb 2-1: Manufacturer: ASIX Elec. Corp.
[ 5392.609634] usb 2-1: SerialNumber: 00010D
[ 5408.263112] eth%d: Reset RX_CTL failed: -110
[ 5408.267571] eth%d: Binding device failed: -110
[ 5408.272160] asix: probe of 2-1:1.0 failed with error -110
vrobi
Postby vrobi » Wed Nov 21, 2012 3:38 pm
Hi deadhp1
Please can you help to compile mcs7830.ko
Very Thanks
Postby deadhp1 » Wed Nov 21, 2012 4:51 pm
binkers wrote:Maybe I could get someone to compile this r8712u driver for me. I've tried to get it to make a module, but have finally given up after several hours of hammering away.
The driver for the r8712u is also in the kernel source. I built as a module for you.
r8712u.zip
Hope it works.
vrobi wrote:Hi deadhp1
Very Thanks
Done!
mcs7830.zip
Thaddaeusmc
Postby Thaddaeusmc » Wed Nov 21, 2012 8:59 pm
How do I compile drivers ? I need the smsc95xx.c for my finless 1.5a build. Is there a comprehensive guide for compiling drivers anywhere ? Actually, just saw there is also a smsc95xx.h, how do I know which one I'll need ?
a.alekizoglou
Usb wifi driver for TPLINK 723N
Postby a.alekizoglou » Fri Nov 23, 2012 4:31 am
I've build the wifi driver for Realtek's rtl8188cu chipset. I've tested that on TP-LINK 723N, on Finless 1.5a. The device works steady on 150MBps, router is 10m away behind the wall, Vigor Draytek 802.11 b/g/n
Note: It's not the same rtl8192cu.ko, but a build with IOCTL enabled.
Check here:
viewtopic.php?f=66&t=231&p=3777#p3777
wahhh
Postby wahhh » Fri Nov 23, 2012 5:04 am
pangyuliu wrote:The finless 1.5a does support Apple usb ethernet device which chipset is AX88772A ...
My AX88772B based USB ethernet adapter works well on finless 1.5a rom.
thamichie
Postby thamichie » Sat Nov 24, 2012 6:57 am
Hey deadhp1, its great that you are trying to help people out here! :)
Could you help me too ? I just keep getting errors in trying to compile the drivers myself :(
http://www.ralinktech.com/en/04_support ... php?sn=501
RT2870USB(RT2870/RT2770)
Thanks in advance!
khonakr
Postby khonakr » Sun Nov 25, 2012 3:40 am
can some1 please make .ko file and necessary files for netgear wg111 v3 with chip Realtek RTL8187B cant find linux drivers any where.. not even on Realtek site! (nor do i know any linux stuff)
i know it isnt nice asking but help! :!: :!: :!:
thnx in advance! would appreciate some help !
Spotopolis
Postby Spotopolis » Tue Dec 04, 2012 4:12 pm
khonakr wrote:can some1 please make .ko file and necessary files for netgear wg111 v3 with chip Realtek RTL8187B cant find linux drivers any where.. not even on Realtek site! (nor do i know any linux stuff)
I would also really like a drive for this chip. I found one and when I tried insmod I got a Exec error
shooter54
Postby shooter54 » Fri Dec 07, 2012 5:59 pm
Hey. I hope that anyone con Help me. I have a D_link DWA-125 USB W-Lan Stick! How can i get the stick Working on the mk808?
Or has anyone a Driver that Work?
acqant
Postby acqant » Thu Jan 10, 2013 5:41 pm
So I've got a Dlink DWA-131 H/W Ver: A1 -- F/W Ver: 1.21 -- so says the box.
I've insmod r8712u with no errors. Kernel detects the usb and sees the mac address but when I turn the wifi to ON
I get all kinds of errors.
ANDROID_ERROR) ##wife_probe
ANDROID_ERROR) wifi_set_power = 1 ( I've tried it in the otg and direct usb slot ( Not a powered usb hub )
ANDROID_ERROR) wifi_set_carddetect:1
Then rk29 stuff, Dongle Host stuff
ANDROID_ERROR) wifi_get_mac_addr
I'm thinking I'll try a powered usb hub?????
r8712u.zip
Hope it works.
Very Thanks
Done!
mcs7830.zip
schintze
Postby schintze » Fri Jan 11, 2013 2:37 pm
r8712u.zip
Hope it works.
Very Thanks
Done!
Thanks for compiling this!
Im trying to get my delock usb->lan adapter to work. problem is, no eth0 interface is beeing initialized.
I do a insmod mcs7830.ko and i get (dmesg)
<6>[  174.537279] MOSCHIP usb-ethernet driver 2-1:1.0: eth0: register 'MOSCHIP usb-ethernet driver' at usb-usb20_host-1, MOSCHIP 7830/7832/7730 usb-NET adapter, 00:13:3b:24:17:50
<6>[  174.553766] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
<3>[  174.565363] qtaguid: iface_stat: stat_update() eth0 not found
<6>[  174.571139] DWC_OTG: frame_number 0x210e, start 0x20df, complete: 1
<3>[  174.577877] qtaguid: iface_stat: stat_update() eth0 not found
<3>[  174.583866] qtaguid: iface_stat: stat_update() eth0 not found
<3>[  174.589694] qtaguid: iface_stat: stat_update() eth0 not found
<3>[  174.595469] qtaguid: iface_stat: stat_update() eth0 not found
<3>[  174.601267] qtaguid: iface_stat: stat_update() eth0 not found
<3>[  174.607081] qtaguid: iface_stat: stat_update() eth0 not found
<3>[  174.612920] qtaguid: iface_stat: stat_update() eth0 not found
<3>[  174.618699] qtaguid: iface_stat: stat_update() eth0 not found
<3>[  174.624504] qtaguid: iface_stat: stat_update() eth0 not found
<3>[  174.630504] qtaguid: iface_stat: stat_update() eth0 not found
<3>[  174.636374] qtaguid: iface_stat: stat_update() eth0 not found
<3>[  174.642281] qtaguid: iface_stat: stat_update() eth0 not found
<3>[  174.648335] qtaguid: iface_stat: stat_update() eth0 not found
<6>[  174.654252] DWC_OTG: frame_number 0x23a7, start 0x2377, complete: 1
<3>[  174.660634] qtaguid: iface_stat: stat_update() eth0 not found
<3>[  174.666725] qtaguid: iface_stat: stat_update() eth0 not found
<3>[  174.672640] qtaguid: iface_stat: stat_update() eth0 not found
<3>[  174.678487] qtaguid: iface_stat: stat_update() eth0 not found
<3>[  174.684317] qtaguid: iface_stat: stat_update() eth0 not found
<6>[  174.690078] DWC_OTG: frame_number 0x24c6, start 0x2497, complete: 1
<6>[  174.696169] DWC_OTG: frame_number 0x24c6, start 0x2497, complete: 1
<3>[  174.702486] qtaguid: iface_stat: stat_update() eth0 not found
<3>[  174.708488] qtaguid: iface_stat: stat_update() eth0 not found
<3>[  174.714306] qtaguid: iface_stat: stat_update() eth0 not found
<6>[  174.720063] DWC_OTG: frame_number 0x25b6, start 0x2587, complete: 1
<3>[  174.726197] qtaguid: iface_stat: stat_update() eth0 not found
<3>[  174.732205] qtaguid: iface_stat: stat_update() eth0 not found
<3>[  174.737987] qtaguid: iface_stat: stat_update() eth0 not found
<3>[  174.743773] qtaguid: iface_stat: stat_update() eth0 not found
<3>[  174.749599] qtaguid: iface_stat: stat_update() eth0 not found
<3>[  174.755389] qtaguid: iface_stat: stat_update() eth0 not found
<3>[  174.761200] qtaguid: iface_stat: stat_update() eth0 not found
<3>[  174.766984] qtaguid: iface_stat: stat_update() eth0 not found
<3>[  174.772779] qtaguid: iface_stat: stat_update() eth0 not found
<3>[  174.778562] qtaguid: iface_stat: stat_update() eth0 not found
<7>[  184.958840] eth0: no IPv6 routers present
I can activeate ethernet in the settings, but I get no IP address. Also assigning a static ip (im sure it was a valid one) wouldnt work either.
I have no clue how to go on from here. Maybe somebody has a hint for me?
cheers, Stef
mcs7830.zip
