use usb wifi adapter on mk808
ApocalypseSticks
Re: use usb wifi adapter on mk808
Postby ApocalypseSticks » Fri Dec 28, 2012 9:36 pm
Hi, I've been having some issues with a new MK808.
MK808, Finless 1.5a ROM
Edimax EW-7811Un // rtl8192us chipset
The USB dongle is plugged into a powered USB hub.
I've tried both rainlake's (page 1) & a.alekizoglou's (page 8) drivers
Method: copy rtl8192cu.ko to /system/lib/modules/ and changed permissions.
Turn WiFi off
Run Android Terminal Emulator
Type 'SU' to enable superuser.
Type 'rmmod /system/lib/modules/rkwifi.ko' to verify it's been deactivated.
Type 'insmod /system/lib/modules/rtl8192cu.ko' (No errors reported. The prompt keeps cycling over and over again until I type something)
Turn WiFi on & system locks up and crashes
The MK808 is replacing an iMito MX1 (fragile usb ports broke) I was able to use the above steps to get it to work on the MX1, but when I try them on the MK808 it either crashes when I turn WiFi on, or WiFi toggling does nothing.
Any suggestions?
chelmix
Postby chelmix » Sat Dec 29, 2012 6:00 am
Hello
My question may seem stupid, but does my device need to be rooted in order to get a Wifi adapter working ?
I there an adapter workong "out ouf the box", without any mods ?
Thx !
najx
Postby najx » Sat Dec 29, 2012 2:22 pm
SOLVED
first i compile kernel source and next compile driver with same errors :( any advice?
    make -C tools
    make[1]: Entering directory `/home/matko/wifi/tools'
    gcc -g bin2h.c -o bin2h
    make[1]: Leaving directory `/home/matko/wifi/tools'
    /home/matko/wifi/tools/bin2h
    cp -f os/linux/Makefile.6 /home/matko/wifi/os/linux/Makefile
    make -C /home/matko/rockchip-rk30xx-mk808/ SUBDIRS=/home/matko/wifi/os/linux modules
    make[1]: Entering directory `/home/matko/rockchip-rk30xx-mk808'
      CC [M]  /home/matko/wifi/os/linux/../../common/crypt_md5.o
    In file included from /home/matko/wifi/os/linux/../../common/rt_config.h:92:0,
                     from /home/matko/wifi/os/linux/../../common/crypt_md5.c:28:
    /home/matko/wifi/os/linux/../../common/mlme.h:1185:27: error: 'MAX_LEN_OF_MLME_QUEUE' undeclared here (not in a function)
    In file included from /home/matko/wifi/os/linux/../../common/rt_config.h:99:0,
    /home/matko/wifi/os/linux/../../common/rtmp.h:644:19: error: 'TX_RING_SIZE' undeclared here (not in a function)
    /home/matko/wifi/os/linux/../../common/rtmp.h:652:19: error: 'RX_RING_SIZE' undeclared here (not in a function)
    /home/matko/wifi/os/linux/../../common/rtmp.h:660:19: error: 'MGMT_RING_SIZE' undeclared here (not in a function)
    /home/matko/wifi/os/linux/../../common/rtmp.h:716:34: error: 'NUM_OF_TX_RING' undeclared here (not in a function)
    /home/matko/wifi/os/linux/../../common/rtmp.h:2546:2: error: unknown type name 'RTMP_INF_TYPE'
    /home/matko/wifi/os/linux/../../common/rtmp.h:2805:2: error: unknown type name 'RTMP_INF_TYPE'
    /home/matko/wifi/os/linux/../../common/rtmp.h:2983:2: error: unknown type name 'TXWI_STRUC'
    /home/matko/wifi/os/linux/../../common/rtmp.h:3324:2: error: unknown type name 'RT28XX_RXD_STRUC'
    /home/matko/wifi/os/linux/../../common/rtmp.h:3325:2: error: unknown type name 'PRXWI_STRUC'
    /home/matko/wifi/os/linux/../../common/rtmp.h:4083:6: error: unknown type name 'INT_SOURCE_CSR_STRUC'
    /home/matko/wifi/os/linux/../../common/rtmp.h:4163:5: error: unknown type name 'PTXWI_STRUC'
    /home/matko/wifi/os/linux/../../common/rtmp.h:4183:9: error: unknown type name 'PTXWI_STRUC'
    /home/matko/wifi/os/linux/../../common/rtmp.h:4189:9: error: unknown type name 'PTXWI_STRUC'
    /home/matko/wifi/os/linux/../../common/rtmp.h:6646:5: error: unknown type name 'PRXWI_STRUC'
    /home/matko/wifi/os/linux/../../common/rtmp.h:6650:7: error: unknown type name 'PRT28XX_RXD_STRUC'
    /home/matko/wifi/os/linux/../../common/rtmp.h:6924:5: error: unknown type name 'RTMP_INF_TYPE'
    In file included from /home/matko/wifi/os/linux/../../common/rt_config.h:100:0,
    /home/matko/wifi/os/linux/../../common/ap.h:86:5: error: unknown type name 'PRT28XX_RXD_STRUC'
    make[2]: *** [/home/matko/wifi/os/linux/../../common/crypt_md5.o] Error 1
    make[1]: *** [_module_/home/matko/wifi/os/linux] Error 2
    make[1]: Leaving directory `/home/matko/rockchip-rk30xx-mk808'
    make: *** [LINUX] Error 2
fratello
Postby fratello » Sun Dec 30, 2012 12:15 pm
Read and read again this topic ... It's a USB WiFi adapter working immediately after plugin into MK808 ? Without modifying anything ?
I would be grateful for some example ! Regards !
yobikap
Postby yobikap » Mon Dec 31, 2012 5:10 am
fratello wrote:Read and read again this topic ... It's a USB WiFi adapter working immediately after plugin into MK808 ? Without modifying anything ?
No there is no USB WiFi adapter that works immediately.
yobikap
Postby yobikap » Mon Dec 31, 2012 5:14 am
yobikap wrote:mirko2002,
I have currently some problem with compiling, so I am not able to test it with my device. I will let you know asap.
Okay I managed to compile the driver, there are problems with the driver. Whenever my device starts by booting this driver, while I have inserted the USB WiFi (using the rt5370 device), the device reboots and reboots.
I think there is somewhere a problem with memory allocation or the memory buffer get's full, however I have managed sporadically that the GUI communicates with the nl80211 driver.
mirko2002
Postby mirko2002 » Mon Dec 31, 2012 8:46 am
Ok so i can leave my idea to get this wlan stick working on boot and i have to start the wlan stick manually over the the terminal app everytime?
PMMIKE
Postby PMMIKE » Wed Jan 02, 2013 1:42 pm
Has anyone tried using this process with a Alfa AWUS036H on a MX2 or MX1 ?
yobikap
Postby yobikap » Thu Jan 03, 2013 5:42 am
mirko2002 wrote:Ok so i can leave my idea to get this wlan stick working on boot and i have to start the wlan stick manually over the the terminal app everytime?
I am really fed-up with this ralink drivers.
I will compile the rt2x00 from the compat-wireless, those are better than the sources that ralink provides.
b0li
Postby b0li » Mon Jan 07, 2013 4:20 am
Will driver for linux (w35und.ko) work on android stick? Are they exchanglable?
Sent from my Nexus S using Tapatalk
yobikap
Postby yobikap » Mon Jan 07, 2013 7:32 am
b0li wrote:Will driver for linux (w35und.ko) work on android stick? Are they exchanglable?
It depends if the android stick has the same kernel (version) or not.
b0li
Postby b0li » Mon Jan 07, 2013 10:42 am
Sent from my NEO-G4 using Tapatalk 2
mrfunnyman
Re: use usb wifi adapter on mk808 - Driver for TPLINK 723N
Postby mrfunnyman » Mon Jan 07, 2013 11:17 am
a.alekizoglou wrote:Thanks to rainlake and ratri, after a lot of digging into Realtek's RTL8192CU and RTL8188CUS driver (http://www.realtek.com.tw/DOWNLOADS/dow ... Down=false) I managed to build the driver that's working for RTL8188CUS based devices.
This is what I've bought http://www.tp-link.com/en/products/deta ... =TL-WN723N
The device's ID is 0BDA:8176 REV_0200
The problem with rtl8192cu.ko driver was that in autoconf.g the line for CONFIG_IOCTL_CFG80211 is remarked. Therefore ioctl is not build with the driver. So I removed the remark and rebuild the driver. It is now working for my device according to the instructions rainlake has provided. That is:
1) copy rtl8192cu.ko to /system/lib/modules after you have mounted with rw (I usually run ESexplorer with root options)
2) rename /system/lib/modules/rkwifi.ko -> /system/lib/modules/rkwifi.ko.old in case you need that later
3) rename /system/lib/modules/rtl8192cu.ko -> /system/lib/modules/rkwifi.ko
4) fix permitions, I do that from terminal, but I think you can do that from ESExplorer as well
chmod go+r /system/lib/modules/rtl8192cu.ko
chown root:root /system/lib/modules/rtl8192cu.ko
So I include the driver in case someone else with RTL8188CUS chipset wants to check.
So I am good until step 4. Sorry for the silly questions but how am I fixing permissions on the file "rtl8192cu.ko" when it was renamed in step 3? IS this a typo or am I missing something.
a.alekizoglou
Postby a.alekizoglou » Tue Jan 08, 2013 7:14 am
Sorry for that, it's a typo. What I meant is
4) fix permit ions, I do that from terminal, but I think you can do that from ESExplorer as well
chmod go+r /system/lib/modules/rkwifi.ko
chown root:root /system/lib/modules/rkwifi.ko
marphsai49
Postby marphsai49 » Tue Jan 08, 2013 4:22 pm
Hi rainlake,
I have a Thomson WLG-1500A with a SIS 163 chipset.
Is there a possibility of making driver for this one?
ID 0457:0163 Silicon Integrated Systems Corp 802.11 Wireless Lan Adapter
I have broken my antenna, so this will be great.
The driver can be downloaded there: (in network driver, 160 series)
http://w3.sis.com/download/
I have the driver, but i don't know how to attach an entire folder on this board :oops:
Thanks,
galarstar
Postby galarstar » Wed Jan 09, 2013 12:34 pm
is this something you can use on a imito mx1 and with a edimax model no. EW7711UAn
please helt me the best connection i can get with my mx2 is ½ mbit and im only 10 meters from my router
eyesoft
Postby eyesoft » Sat Jan 12, 2013 6:55 pm
can you help me with this :
on dmesg
<6>[ 103.873799] usb 2-1.2: new high speed USB device number 20 using usb20_host
<6>[ 103.991701] usb 2-1.2: New USB device found, idVendor=148f, idProduct=3070
<6>[ 103.998926] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
<6>[ 104.006304] usb 2-1.2: Product: 802.11 n WLAN
<6>[ 104.010695] usb 2-1.2: Manufacturer: Ralink
<6>[ 104.014933] usb 2-1.2: SerialNumber: 1.0
<4>[ 104.024351]
<4>[ 104.024354]
<4>[ 104.024356] === pAd = faeff000, size = 520792 ===
<4>[ 104.024359]
<4>[ 104.034906] <-- RTMPAllocTxRxRingMemory, Status=0
<4>[ 104.039738] <-- RTMPAllocAdapterBlock, Status=0
lsusb : Bus 002 Device 020: ID 148f:3070
iwconfig : wlan0 Ralink STA
ifconfig wlan0 up
wlan0 Ralink STA ESSID:"11n-AP" Nickname:"RT2870STA"
Mode:Auto Frequency=2.412 GHz Access Point: Not-Associated
Bit Rate:1 Mb/s
RTS thr:off Fragment thr:off
Encryption key:off
Link Quality=10/100 Signal level:0 dBm Noise level:0 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
when i try to get from android settings on i get this :
<4>[ 125.346039] Current WiFi chip is RK901.
<4>[ 126.829348] Current WiFi chip is RK901.
logcat :
D/WifiService( 266): setWifiEnabled: true pid=1282, uid=1000
D/WifiHW ( 266): Read wifi chip type OK ! wifi_chip_type = RK901
D/WifiHW ( 266): wifi_load_driver: DRIVER_MODULE_PATH = /system/lib/modules/rkwifi.ko, DRIVER_MODULE_ARG =
E/WifiStateMachine( 266): Failed to load driver!
E/WifiStateMachine( 266): DriverFailedState
i replaced rkwifi.ko with rt3070sta.ko , and replaced in init.rk30board.rc
service wpa_supplicant /system/bin/wpa_supplicant \
-Dwext -iwlan0 -c/data/misc/wifi/wpa_supplicant.conf
thnx
acqant
Postby acqant » Tue Jan 15, 2013 8:39 pm
Would love to get the bottom of the
Current wifi chip is xxxx
I'm trying a new kernel out with NO WIFI. Just to see wtf happens when I press the wifi button. I see in the realtek sources they have something that will build a wifi.ko module that will work with the new drivers but this is such a convoluted process and I'm luck I got as far as I have.
stinger
Postby stinger » Sat Jan 19, 2013 6:15 am
Hi my builtin wifi is very bad in my MK808 so if some1 could help me wiyh the driver and how I shall do to make it work I would be very happy and I can pay if somebody is willing to waste some time on me.
My adapter is konig http://www.konigelectronic.com/en_us/1118052 driver is on the same page under download. The chip seems to be RTL8192su if I look in the manual. So if someone could tell me what to do or write an step by step guide I would be very happy.
Thank you.
shooter54
Postby shooter54 » Sun Jan 20, 2013 12:34 pm
Hey. Is there anywhere a working rt5370.ko driver?
This would be awsome.,
