Install Picuntu on Internal Nand
gripped
Postby gripped » Mon Apr 15, 2013 7:02 am
update
(I have now installed debian wheezy via debootstrap. The below still applies and I needed Picuntu to do the debootstrap. The instructions below are intentionally vague !. In a nutshell what I have done is add the rk30xxnand_ko.ko to initramfs.cpio and insert it so that the kernel can find root on the mtdblock. I will write all this up properly on my blog when I get time. )
Hi
I've spent the weekend trying to do this and have had some success. I am sharing this in case anyone else is trying to do the same thing.
If this has been covered already then sorry but I did not come across it.
The Repo is https://github.com/gripped/MK808-headless-nand-3.0.8-rk3066
All you need should be there ?
Still needs tidying up. I am not planning on supporting or releasing this at all but it may be of use to someone ?
README.md
Install Picuntu on Intenal Nand
First of all this is in a state of flux and may be broken at any time.
I would have liked to fork repos and pull from here and there but do not yet know much about git so I'm uploading this as a whole.
Credits to AndrewDB , Omegamoon, alok & finless bob
The kernel tree is from
https://github.com/aloksinha2001/picunt ... ksinha2001
The toolchain is taken from Omegamoons tree
https://github.com/omegamoon/rockchip-rk30xx-mk808
The original initramfs.cpio is from
https://github.com/Galland/rk30_linux_initramfs.github
the mkbootimg is from
The config is based on Picuntu 0.9 RC2 as RC3 was throwing up hung process errors
I started this as my intention is to run a mail relay on my MK808 on my home FTTC connection.
(I have a couple of cheap, but fair powerful for the price, servers where the provider blocks port 25 and I don't want to use their relay if I can avoid it)
I don't need Android on the device at all and it seems a waste to leave the internal nand almost unused.
First I wanted to get a functional Picuntu on the internal Nand, this is done.
Next I will be optimizing the kernel for headless running. Anything not needed will be disposed of.
I'm still waiting for a Network switch and once I have it wifi will be going from my build as well( but I'll leave configs in place)
Only tested on MK808. I do have a MK808B as well so may try this later (no wifi or BT) but other models YOU ARE ON YOUR OWN
This will stop Android working on your device (though you can flash it back)
If you don't understand why I suggest you stop here.
Doing it ! (Don't blame me)
Install Picuntu 0.9 RC2 and make sure its working fully on the sdcard.
The kernel build tree is self contained and I think you should be able to build without to much extra packages
Of the top of my head I had to install SHA something and LZO something (I'm on arch)
Look at this compilation errors if any and you'll work out what missing
You need to have your MTD blocks / partitions laid out as I have set up in the configs Kernel CONFIG_CMDLINE
The parameter file is in the root directory "parameter1gb"
Flash Finless bobs 2.0 MK808 rom with the parameter1gb and you get the right layout
http://www.freaktab.com/showthread.php? ... M-2-0-BETA
Copy ./modules/rk30xxnand_ko.ko.3.0.8+ to the /lib/modules/kernel/rk30xxnand_ko.ko on your sdcard and on the MK808 run depmod -a
run ./build_rk3066_standard
and in BUILT you will find sdcard_boot.img.
Flash it to boot
On picuntu
modprobe rk30xxnand_ko.ko
cat /proc/mtd
should show mtd partition. If not its not working , figure it out.
mkfs.ext4 /dev/mtdblock9
mount /dev/mtdblock9 /mnt
rsync -avx / /mnt
umount /mnt
On PC
run ./build_rk3066_mtd
and in BUILT you will find mtdboot.img.
Flash to boot
Everything works and you are happy.
As I say this is stiil a work in progress
The modules these compilatons produced did not work (missing symbols) but the set already on my picuntu install did.
I will investigate
The rk30xxnand_ko.ko I took from the MK808 rom worked on Picuntu but had were odd on my PC. (cp cannot stat)
So I took one from here
https://github.com/jin-eld/cm_rk3066_ve ... o.3.0.8%2B
It might brick your entire life ?
To Do
Test jffs2 & ubifs
Benchmark internel nand vs class 10 SD
Try to implement raid1 between nand & SD
Make headless version of kernel
Find any improved code in other repo's
Anything I think of.
gallando
Re: Install Picuntu on Internal Nand
Postby gallando » Fri May 24, 2013 9:12 pm
AWESOME!! Thank you very much for sharing your work!
gripped
Postby gripped » Thu May 30, 2013 1:54 pm
Pleased to hear it was of use to you. :D
tonikasch
Postby tonikasch » Tue Sep 03, 2013 6:50 pm
gripped, I'm really interested in your work.
Any advance?
What is your blog?
Thanks!! :D
MK808 as server, waiting for full Mali-400 support
Minix X7 arriving home mid September to bring it full linux support :)
...Itaca te ha dado el bello viaje. Sin ella, nunca habrías salido...
