Help with Uhost 2
micke_moose
Help with Uhost 2
Postby micke_moose » Sun Jan 27, 2013 9:08 am
I've had my Uhost 2 for about two weeks and it worked with no problems. But now it won't start. There is no picture on the tv and the light on the Uhost 2 flashes between blue and grey. It won't connect wirh my pc either thru usb.
Anyone that can helo me with this problem?
majack
Re: Help with Uhost 2
Postby majack » Thu Feb 28, 2013 7:18 am
Check your HDMI connect.
Blue and Grey is mean HMDI sign can not put out
gooplusplus.com
Contact:
Postby gooplusplus.com » Wed Apr 10, 2013 6:01 pm
If it is still not working, you may need to install newer firmware using RKBatchTool 1.6 and a Windows PC USB 2.0 port (USB 3.0 ports don't work).
You need to install the USB drivers first (look in the RKBatchTool RockUSBdriver directory).
The firmware that worked best for me is here:
http://www.probox2.com/
Return to “uHost 2”
