MK808 webcam support and skype video chat support
Postby geekbuying » Sat Dec 08, 2012 4:12 am
Hi guys:
Recently we get some information about how to set the webcam work on MK808.
Today i make a test by myself. I use the following two device:
1 USB HUB:
http://www.geekbuying.com/item/High-spe ... 00706.html
2 Webcam:
http://www.geekbuying.com/item/Logitech ... 12647.html
and i run the " camera ICS" app in MK808, in this app, the camera runs well, just like in your tablet or cell phone which build in camera.
and i also run the skype video chat test on those two accessories, also works well.
The camera i use is Logitech C170, it is original and good quality, and then , i change another hub(cheap ones) to test, the camera won't work. I guess, some people report the camera can't work well, it is the problem for their hub.
Hope this information is helpful.
salundy
Re: MK808 webcam support and skype video chat support
Postby salundy » Mon Dec 10, 2012 5:15 am
Can it also works without any usb adapter?
Does it work with some other webcam´s with different chipset´s?
I have a Logitech Quickcam 4000, but i get only the microphone in the Skype app.
Is it possible to use an universal webcam driver on the MK808? Where can i get it?
homman
Postby homman » Thu Dec 13, 2012 11:39 am
DOES NOT WORK.
How do you check it?
You must call to another skype!!!
And that you can see an image from the camera in the window
This does not mean that the recipient gets it!!!
microsoft hd 5000 or logitech c510 on it you said that it works. I see stripes only!
homman
Postby homman » Sun Dec 16, 2012 10:39 am
The camera works!
mk808 has a mistake in the firmware. Causing the camera will only work on the OTG connector!
But not everyone s skype support full hd.
We created a test program the camera.
http://www.sendspace.com/file/hl9a6u
http://download.hellshare.pl/test-cam-a ... /10477312/
Probably all the cameras from the list below should work on connector OTG
And Skype_2.8.0.920 or Skype_2.8.0.920
http://www.ideasonboard.org/uvc/
Only one problem i have.
No connection to the usb lan adapter. After a restart.
My friend has a different lan adapter and there is no problem.
On mk802 II no problem.
minitvstick.com
Postby minitvstick.com » Sun Dec 16, 2012 5:07 pm
I upgraded by MK808 stick with the Finless 1.5a ROM and then my webcam/mic started to work with Skype. Just posted up blog entry.
(The video does not show skype as I have not had time to load this up yet...)
http://www.minitvstick.com/blog/?p=278
The Microsoft LifeCam Cinema I had did NOT work before the upgrade (I have a video on that as well :)) Here's the Skype performance with the Microsoft camera BEFORE the upgrade:
http://www.minitvstick.com/blog/?p=259
Enjoy!
Sticking it to the big PC
homman
Postby homman » Sun Dec 16, 2012 8:47 pm
As I said
This is a list of cameras that work with android
life cam cinema have not compatible sound.
Most cameras will only work on OTG port.
Only my tests helped determine this.
Unfortunately, the majority lan> usb adapter also works only on the OTG port.
Of course there are cameras operating on a USB but they are usually low resolution.
Does the camera runs on USB or OTG, we can easily see the camera application.
Making sure that we see the resolution of the camera.
It may be, as in my case.
hd5000
Usb skype does not work. In the application, we have a low resolution camera.
OTG working on skype. In the application, we have a high resolution camera.
Of course it may also be too little energy from usb.
Cam could work on usb. But have not too much energy.
BUT NO ALL CAM WORKS ON USB. Most HD cam only works on OTG
The best software for mk808 are:
viewtopic.php?f=13&t=903
or
Minix Neo X5 Kizs V2 720p
The fastest and best soft 1.5 ghz 720p
http://ul.to/arhqiddp
http://uploading.com/c3bm8ce5/Android-4 ... X-Mode-exe
For 802 mk II We have firmware with skype soft.
It is HBD400 and skype Skype_2.9.0.315 or Skype_2.9.0.900
http://ul.to/vf9cd8z6
Tell me where to send it. senspec or where.
I'm sorry for my English but mayby can understand me
If i helped you please donate my English lesson :)
https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=ZAFFHWHZULRTN
sumanto
Postby sumanto » Tue Dec 25, 2012 7:09 pm
MK808 works with Skype (Video and Audio). I have updated my MK808 with Finless 1.7 ROM (which was published for UG802) and Kizs kernel (kizs_kernel_1.5GHz_1080.img). Logitech USB CAM (Model C110) works perfectly with updated firmware. No issue on Video and audio.
Kizs kernel (working kernel for USB Cam):
https://dl.dropbox.com/u/44128030/kizs_ ... Hz_720.img
https://dl.dropbox.com/u/44128030/kizs_ ... z_1080.img
Finless Rom:
https://docs.google.com/file/d/0B9BFwCz ... edit?pli=1
I have made a post with images at freaktab website for growing community of MK808
http://www.freaktab.com/showthread.php? ... #post43234
Note: FYI.. Skyepe is not working with Kizs Latest published kernel (kizs_kernel_v2_1.5GHz_1080_USBETH+BT.img) for MK808 at my setup
Sumanto
minitvstick.com
Postby minitvstick.com » Wed Dec 26, 2012 10:55 am
Have had too much time this holiday season so did a novelty video to show the results of some tests with mk808 and Microsoft LifeCam Cinema. Just to be clear the camera and mic workes with the device so the list mentioned earlier may be out of date. Some stability issues but then I expect this with this generation of product for the moment....
It did not work 100%, but is probably good enough for most people!
http://www.minitvstick.com/blog/?p=308
Enjoy!
alexgold
Postby alexgold » Mon Dec 29, 2014 3:21 pm
Sorry dear I do not have idea about this. You can contact Skype help for this. From here you can get your solution . I am 100%sure.
