XBMCFrodo Beta2 Neon Android 1080p HW + DTS MK808 (Download)
Postby lewy20041 » Fri Dec 07, 2012 7:01 am
XBMC Android HD Playback Setup by lewy20041
http://www.youtube.com/watch?v=cVe-QPkz ... e=youtu.be
Download in movie discription on youtube. Have fun
-Unpack playercorefactory.xml, for MX Player Pro or the one for Mx Player free.
-Transfer the files over to your device.
-Install XBMC.apk through a file manager.
-If you want to play movies from NAS/FTP you need to install cifs manager and mount your shares as internal disks, after that go to XBMC click on Video>Add Source>Root File System>mnt> and choos your HDD.
-Return to the file manager and Copy playercorefactory.xml and advancedsettings.xml. Navigate to Android/data/org.xbmc.xbmc/files/.xbmc/userdata and copy PlayerCoreFactory.XML there.
-If you want Xperience skin for XBMC just install System>Add-ons>Install from zip file>External storage>repository.blacks and then go to System>Add-ons>Blacks Repo>Skin>Xperience1080.
-If ou want dts sound extract the files from the mx_dt_scodec.rar and copy them to your device Sdcard then, in MX Player, Go to Settings -> Decoder, scroll all the way to the bottom, and tap Custom codec.
Then, select the folder containing the codec files you copied over and tap OK. MX Player will then close, and after you restart it you should be ok.
Lewy20041
Shifty-PK
Re: XBMCFrodo Beta2 Neon Android 1080p HW + DTS MK808 (Downl
Postby Shifty-PK » Fri Dec 07, 2012 2:26 pm
Does this also play surround sound 5.1 dts?
Will be the first time i see this on the mk808!
Postby lewy20041 » Fri Dec 07, 2012 4:48 pm
i dont know... mayby. for me it play the video file with sound wich befour there was no sound. tray it and post back if you could:)
marcedli
Postby marcedli » Fri Dec 21, 2012 1:01 pm
lewy20041 wrote:i dont know... mayby. for me it play the video file with sound wich befour there was no sound. tray it and post back if you could:)
links in video description are down
Sent from SGS III GT-I9300
Postby lewy20041 » Sat Dec 22, 2012 4:54 am
links are working again
MRAB
Postby MRAB » Sun Dec 30, 2012 6:46 am
Will this hw mod work with NAVI-X add on?
and will it work with the standard xbmc release or do i need to remove and install this version?
sliderem
Postby sliderem » Sun Jan 20, 2013 12:50 pm
lewy20041 wrote:XBMC Android HD Playback Setup by lewy20041
Lewy20041
In my case if I use the CIF Manager and MX Player it seems that the movies are lagging. This thing is not happening with SMB ,but unfortunately the SMB client fromXBMC is not working with all my SMB shares from the network...it simply dos not connect even if the ESExplorer is working fine
sliderem
Postby sliderem » Sun Jan 20, 2013 5:31 pm
It seems that the MXPlayer is not working for SMB shares from XBMC. And if I you use the CIF local mount shares the MXplayer is lagging!
Do you have a good working solution who to use a SMB share with XBMC and with MXPlayer ? Thanks !
