Blank screen when turn on with mHDMI > VGA adapter
vpropely
Postby vpropely » Sat Jan 25, 2014 3:53 pm
Hello! I apologize in advance for bad english and thank you for your attention.
I turn Mk808 through adapter mhdmi > VGA, but screen blank. Previously, everything worked.
Factory default firmware. How do I check what is not working: video chip on the MK808 or adapter mhdmi > vga? Access to devices with HDMI port is missing.
chrisofnaki
Re: Blank screen when turn on with mHDMI > VGA adapter
Postby chrisofnaki » Fri Jan 31, 2014 4:33 pm
Hi
I have same problem, can't work out the problem.
Did you try unbrick nand, I did but not sure if i have correct drivers installed.
Users browsing this forum: No registered users and 3 guests
