unable to flash mk808 because of no usb storage mode
hylst
Postby hylst » Tue Jan 07, 2014 1:57 pm
Hello !
My mk808 is slow, playstore do not find many many apps, not rooted for remote control app with smartphone (?), but most important : wifi works only sometimes or seems to connect...but no... with good signal detected altough.
So, i've spent several hours reading this forum and Finless howto doc to flash my stock rom mk808 from gb (12/2013) android 4.2.2 for finless 2.1c custom.
But I failed ! =D -> Found RKAndroid Loader Rock Usb. ( and not usb mass storage )
It is not an msc device says the rom flash tool.
Reset long press + plug ok, device detected, but... not as usb storage... rather like mtp.
I used provided drivers (finless archive). Debug mode unchecked, connect to pc checked.
Tried to reboot computer 2 times...
" make sure that a) USB storage is turned ON"
but where else ? into android settings, i found no usb storage management but only connect to pc option and developper options suc as debug mode.
Please help me ! Im getting crazy =S
mk808
v android 4.2.2 kernel 30.36+ 5 sep rjh V 403j2 96 soft v 306j2 05 09 2013
Re: unable to flash mk808 because of no usb storage mode
Postby deadhp1 » Wed Jan 15, 2014 3:44 am
Does your android settings have a Storage menu?
If so then there should be an options menu in the upper right corner(three vertical dots).
That should enable you to change the mode to Mass Stoarage and allow the MK808 to be detected by the flash tool.
