Windows8 dosent see new device
ZzackK
Postby ZzackK » Wed Nov 14, 2012 4:19 am
Hello
I cant install new firmware because WIN8 dosent see new device. How fix it?
antieco
Re: Windows8 dosent see new device
Postby antieco » Thu Nov 15, 2012 3:41 pm
Try another USB cable, a quality one, like the ones provided by well known mobile brands.
I was having the same issue, but after using a cable from the Nokia N70 the OS recognized it.
ZzackK
Postby ZzackK » Fri Nov 16, 2012 3:31 am
Back panel works fine. thx
johnjoshyy
Postby johnjoshyy » Fri Feb 15, 2013 7:31 am
can any one tell me that windows 8 support on my Nokia Asha 303
losl
Postby losl » Sun Feb 17, 2013 2:03 am
I have the save problem, my Win PC did not see MK808 when connected so
How did you get your Windows PC to recognize MK808?
How did you connect them?
Which port were you use in MK808?
Thank you for your help !
SLo
backlund
Postby backlund » Sun Feb 17, 2013 4:59 pm
Here's what you have to do to get this working in Windows 8. NOTE read all the instructions first, because you need to reboot in the middle of the steps.
1. Go to the stupid metro start screen.
2. Hover your mouse in the bottom right until the hidden icons appear.
3. Click Settings.
4. On the settings panel, click "Change PC Settings" at the bottom.
5. Click the "General" heading.
6. Scroll to the bottom and click "Restart Now" under the Advanced Startup. Your PC will reboot.
7. When it restarts, it will prompt you with a menu. Click "Troubleshoot".
8. Click "Advanced Options".
9. Click "Startup Settings".
10. Click "Restart". Yes, you have to restart AGAIN.
11. After it restarts, a new boot menu will appear. Type the number that corresponds with "Disable Driver Signature Enforcement". I think it was number 7, if I remember correctly.
12. Windows will now load. Once it has done so, plug in your device. It may or may not automatically detect. If it doesn't, from the desktop hover your mouse over the bottom left corner and Right click.
13. Choose "Device Manager" from that menu.
14. From the device manager you will now be able to install the drivers for the device.
banray8
Postby banray8 » Sat Feb 23, 2013 11:17 am
For me with Win7 X64, USB connector on the front of my PC would not work. I unplugged printer and used the USB connector on the back of the PC. (Maybe I had too many USB devices (5) connected to PC, or I had USB device software conflict, I don't know). Also, on Win7, Win8, use F8 during boot to select "Do not verify Driver Signature.
papam
Postby papam » Sat Jul 13, 2013 7:22 am
almost same issue with me for month what to do
htc mobiles
Windows Phones
Veronica
Postby Veronica » Sat Aug 10, 2013 6:02 pm
Watch "[HOW-TO] Flash a Custom ROM from Stock Factory ROM in the MK808/B" on YouTube - https://www.youtube.com/watch?v=_mDFmP8sXNk&feature=youtube_gdata_player
Sent from my SAMSUNG-SGH-T989 using Tapatalk 2
