Multichannel Audio 5.1 / 7.1 with MK808 (AC3 / DTS / AAC)
salundy
Postby salundy » Wed Nov 07, 2012 10:39 am
does it anyone know?
I tested several videoplayers with my MK808, but no one can output 5.1 sound from the AC3 or DTS sources.
I have installed the Rom Finless 1.5a.
I put the MK808 in a HDMI slot of my Onkyo NR616 A/V Reciever, but he gets only a PCM 2.0 signal from the TVstick.
Thanks for your answer. ;-)
Gesendet vom Samsung SGII mit Tapatalk.
www.salundy.de
reddragon72
Re: Multichannel Audio 5.1 / 7.1 with MK808 (AC3 / DTS / AAC
Postby reddragon72 » Wed Nov 07, 2012 10:59 am
There is a link on post 8 of this thread from XDA that has something that may work.
http://forum.xda-developers.com/showthr ... ?t=1803871
Try it and tell me if that helps.
salundy
Re: AW: Multichannel Audio 5.1 / 7.1 with MK808 (AC3 / DTS /
Postby salundy » Wed Nov 07, 2012 12:16 pm
Ok thanks. I'll test it tonight after work.
www.salundy.de
salundy
Postby salundy » Wed Nov 07, 2012 8:07 pm
I have tested the dice pkayer, but he won't work. When i start him, with or without video, i got only a message : "Sorry, this video can't be played."
Although, i opened him without any video file.
Is there missing a codec or anything? Also a reinstall from play store couldn't solve this issue.
www.salundy.de
reddragon72
Postby reddragon72 » Fri Nov 09, 2012 1:02 pm
Hmmmm..... I have seen other's on here using the Diceplayer so I do not know why it would not handle it.
See if MX player will handle the file, but MX player will not output 5.1 as I have tried several times.
ciaoboy
Postby ciaoboy » Fri Dec 21, 2012 7:48 am
Ive got an MK808 Dice doesnt start as per the above response and MX doesnt output 5.1A
muratremix
Postby muratremix » Fri Dec 21, 2012 10:10 am
Without 5.1 audio, these sticks are useless as main media players.
They are okay to use in Bedroom LCD though.
ADD
Postby ADD » Fri Dec 21, 2012 11:17 am
salundy wrote:Hello,
http://www.salundy.de
Hi, I've got no problem with playing AC3 6ch sound that I pass first to my Toshiba TV with HDMI, then I use the SPDIF (optical) of my TV that I send to the receiver. It works correctly. It must be somewhere in your TV where you have to change audio settings from PCM2 to HDMI.
Good luck!
arogan
Postby arogan » Tue Jan 15, 2013 6:02 pm
Just wanted to chime in I have the same issue. MK808 on finless 1.6 and no matter what I try I can't get ac3 or dts bitstream 5.1 passthrough to work so I can get true 5.1 sound. Everything gets down sampled to 2 channels. It really is too bad b/c this is a deal killer for using these things as media players. Otherwise it is decoding 720p/1080p mkv's just fine.
Users browsing this forum: Majestic-12 [Bot] and 1 guest
