MK808 newest firmware release
hrodeberht
Re: MK808 newest firmware release
Postby hrodeberht » Sun Dec 02, 2012 8:01 am
@wings: not out of the box. Tried with the ICS and all released Jelly Bean Versions.
I used the compiled module from deadhp1 and loaded it sucessfully (tried with JB from released at 03.11), but the problem persists. I Switch LAN on and some seconds later the switch jumps back to off. I thought it was, because missing network module, but it does not helped. So no LAN at moment. When I have time I will try to install the module in the newest firmware release (28.11.2012). Tried cyanogenmod too, but the same ....
@salundy This is not an official release from factory, so it has possible not the offered features from geekbuying. From geekbuying blog.
Big Thanks to my US Friend, we are finally working out a real 1080p firmware for MK808, here is the firmware download link:
He has compiled the kernel with /proc/config.gz support. Will have a look if he has compiled modules for webcam-support and which ones.
Regards
Robert
hrodeberht
Postby hrodeberht » Mon Dec 03, 2012 5:17 pm
with the newest firmware version (1080p one). I installed the compiled module from deadhp1 and after that the network switch stays on.
After reboot i need at moment to load the module manually again. But I'am happy that it works.
Output from dmesg:
[ 2659.563156] MOSCHIP usb-ethernet driver 2-1:1.0: eth0: register 'MOSCHIP usb-ethernet driver' at usb-usb20_host-1, MOSCHIP 7830/7832/7730 usb-NET adapter, xx:xx:xx:xx:xx:xx
[ 2659.584526] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 2670.510488] eth0: no IPv6 routers present
Output (partially) from ifconfig
eth0 Link encap:Ethernet HWaddr xx:xx:xx:xx:xx:xx
inet6 addr: fe80::260:6eff:fe41:14ef/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:9 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:1494 (1.4 KiB)
When yet the Access-Point Part from the mk808 Stick works it would be a great. Wanted to use the Stick for (Internet)-Streaming and AP for my PC/Mobile.
At moment the stick get no ip. The cablemodem saves the mac from the connected device. need to power of the modem over night to be able to use another device.
Good Night wishes
robert
wings
Postby wings » Tue Dec 04, 2012 11:39 am
@hrodeberht
Same result here with latest mk808 1080p in Finless 1,7 UG802.
Cable modem/router gives no connecting information but
the network led lamp on router is on so i'm certain the usb dongle tries to connect:
When i power the usb ethernet/usb from 5v and connect to the router,
ethernet/usb led is on, and router rj45 led is off.
When connected between mk808 otg and router rj45, led on router is on.
Typing dmseg in terminal gave same lines as yours, among others.
Maybe someday somewhere someone ...
Meanwhile, wi-fi and paper clip antenna do a decent job.
Good afternoon
dav_id
Postby dav_id » Thu Dec 06, 2012 5:47 am
I have rotation issue with my Google Play Music, some time it doesn't rotate to the landscape mode.
It look like portrait mode that stretch to landscape view...it look weird & the setting option is missing.
Sometime it work perfectly, someone don't..
Any one have the same issue? & how can I force it to be in landscape?
abid123
Postby abid123 » Mon Dec 10, 2012 6:26 pm
I have been using the Finless 1.4 Rom but haven't upgraded because of the resolution change. People had issues with the 1024x720 resolution but my on Samsung 50" Plasma it manages to fill the screen whereas the 1280x672 doesn't. What I want to know, is there any way to change the resolution on the Finless 1.5a firmware so I can change it to 1024x720?
Cheers
Shifty-PK
Postby Shifty-PK » Wed Dec 12, 2012 11:08 am
sn0w
Re: AW: MK808 newest firmware release
Postby sn0w » Wed Dec 12, 2012 11:26 am
Shifty-PK wrote:New FW by Geekbuying: http://blog.geekbuying.com/index.php/20 ... -download/
hope you saw that thats the one for the new 808b with rk903 wifi/bt chip...
Gesendet von meinem GT-P7500 mit Tapatalk 2
stelin
Postby stelin » Wed Dec 12, 2012 11:36 am
That should not matter, there is old mk808 with the same chip out
its differ only in Bluetooth mobile function, it should work as well on our
paca5
Postby paca5 » Thu Dec 20, 2012 11:53 am
geekbuying wrote:3) real 1080p problem. I also know the problem after you guys report, and after long time research, i find now all of the tv stick in market have this problem, see it is the problem for rockchip, and as far as i know, now the NEO G4 factory are working on this, they said on the end of Nov, they will release an android 4.1 update, and which can support real 1080p, and once there is one factory fix the problem, all of the other factory can copy this, and update on their device, we will see it.
thanks!
Hmm... Today 20.12.2012 ...?????
zyi
Postby zyi » Sat Dec 22, 2012 8:50 am
this is a newer version of the mk808
can someone root this,
thks
https://docs.google.com/file/d/0B_0gvJv ... edit?pli=1
napalmique
Postby napalmique » Tue Jan 15, 2013 5:31 pm
Hi everyone,
it seems to me that there are 2 different wireless issues:
- the hardware one, which gets fixed by extending the wires;
- and a software one, the limit to 65 mbps in the conf files in /sys/modules/cfg blah blah
Lucky me, I dont have a hw problem, link speed is stable to 65 mbps, was anyone able to fix the sw problem and break through to 100ish mbps ?
Thanks and apologies if it was answered in a previous post that I might have missed.
matobj
Postby matobj » Wed Jan 16, 2013 5:32 am
I have a error when I run Google Play Store:
"Error retrieving information from the server. [RH-01]"
Just tried this, but to no success:
"Open the" Google Play "app and press the home button to return
Go to Settings → Applications → Manage Applications
Select the "ALL" tab, search for "Google Play Store" and press it to open.
Press "Clear cache"
Press "Force Stop"
Return to Settings → Applications → Manage Applications
Press the "Google Services Framework"
Press "Clear Data"
Press "Force Stop"
Start "Google Play Store" and it should give an error
Reboot.
Once your device has restarted Google Play Store should work. Wait a minute or too if it does not.
This should help if a corrupt cache is the cause of your problems (a corrupt cache might lead to strange error messages, amongst others). If it does not help, you might try the same steps but include "Clear Data" for the playstore app. "
When I click on the blue icon "Google" then we will report an error "Network Error ..."??
Date, time and regional settings are fine.
Other applications (YouTube, Gmail ...) work without problems.
Please help :(
zsirmo
Postby zsirmo » Thu Jan 24, 2013 4:11 pm
Dear Members,
I tested wifi speed problem on MK808. Test AP is Mikrotik AP(professional wifi solution)
I have concluded that the linux kernel driver problem.
Check AP screenshot.
MK808 wifi only use one chain, and sync only 802.11g rates (max. 54Mbit/s)
best regards Attila
Christano
Postby Christano » Mon Mar 25, 2013 11:55 pm
Maybe you can try this step
1 Changelog:
a Change the CPU frequency to 1.6Ghz, (tested by antutu benchmark)
b fix the Screen Rotation in apps problem;
c Move back the ” enable ADB option” choice
d Improve the wifi signal better;
You also need to download the USB driver and the flash tools here:
Firmware update guide:
Step 1: Download all the file from the link i attach, you will get 3 files, one is the firmware with *.IMG formate, the other are two compressed files.
Step 2: Decompress that two files, you will get two folder, one name is “RockusbDriver”,this is the USB driver for MK808, there are different version (win7,win xp,win vista), please choose the correct one when you install the driver; the other folder name is” 量产工具1.5″ this is the flash tool;
Step 3: Connect your MK808 mini pc with your computer, and install the driver:
here is very important, please find a clip, and insert it into the hole ( i mark the hole with the red circle, check following photo)
chismay
Postby chismay » Mon May 06, 2013 6:24 am
just a short chime-in..
had the disconnect or drop to 5mbps every 10 mins,
i updated to bob finless 1.7c changed my router to channel 13.
1 week later not a single disconnect or drop in speed 65mbps constant :D
genny
Postby genny » Tue May 07, 2013 6:02 pm
A suggestion for your wifi problems:
Remove the app ehomemediacenter from system/app
Disable rkupdate from settings.
Restart you router, and test the network. Ehomemediacenter send strange broadcast packets that make crazy your router.
