MK808 green screen problem.
sbt
Postby sbt » Sat Mar 16, 2013 7:41 am
Helo.
Problem with MK808.
When connected to a TV green screen appears.
http://img829.imageshack.us/img829/7631/37874520.jpg
I checked on all HDMI TV I have in effect the same.
Other equipment connected to the HDMI function normally.
On another TV problem does not occur.
Any suggestions?
Thanks and Regards
Does anyone have a similar problem?
dirosa
Re: MK808 green screen problem.
Postby dirosa » Mon Mar 18, 2013 12:06 am
Try another cable
audiobore
Postby audiobore » Mon Mar 18, 2013 5:44 am
Hi, check the rating on the power supply. If it is 1A this will not work (known weakness). 2A supply will do the job.
sbt
Postby sbt » Tue Mar 19, 2013 6:16 pm
I have a power Adaptor:
Model: LA-520
Input: 100-240VAC0.3A
50/60Hz
Output: 5V-2000mA
I checked the cable on another TV with the same power - the problem did not exist.
Any other solutions?
