How can i run picuntu after power on?
beebuu
Postby beebuu » Wed Feb 20, 2013 12:39 pm
I flashed a picuntu followed the article.I need the mk808 run into picuntu after power on,how can i do that?
Please,anyone tell me can i flash the kernel with name the kernel file to kernel.img?
larsnick
Re: How can i run picuntu after power on?
Postby larsnick » Mon Feb 25, 2013 11:11 pm
Beebuu--
Most of the questions you're asking can easily be found on the PicUntu website. Long story short:
1. flash the kernel image to recovery, not kernel
2. after flashing the picuntu kernel to recovery, boot up into Android; your device should do this automatically
3. assuming you're using a rooted rom like finless 1.6 (specifically recommended on the PicUntu website): from android, use the reboot app to reboot into recovery; Picuntu should then boot to the commandline. After that, you're kind of on your own.
Go to the PicUntu website: http://ubuntu.g8.net. All of the above is fairly clearly explained.
beebuu
Postby beebuu » Wed Feb 27, 2013 9:11 am
THANKS for your reply.I mean how to power on and auto run picuntu without any control.
povlhp
Postby povlhp » Wed Feb 27, 2013 10:21 am
You can install picuntu kernel to the default boot rom instead of recovery partition, or you can follow instructions here, and it will boot picuntu if SD card present:
viewtopic.php?f=4&t=738&start=20#p4528
remember you need to use smanager to ensure the script runs at boot.
beebuu
Postby beebuu » Wed Feb 27, 2013 8:59 pm
TONS THANKS! That's what i want!
Users browsing this forum: No registered users and 4 guests
