How I solved problem with Wifi drop down
solorajder
Postby solorajder » Mon Feb 18, 2013 2:02 pm
Hello.
I've had a big problem with Wi Fi drop down on my MK808.
I tried a few things like:
- unsolder the GND from original antena cables and
- disconect both original antenas and connect external antena with and without GND and
- flash to new rom(finles 1.6) and
- change the default channel on router on channel 10
but nothing helped. Wi Fi still drop down.
When I no longer know what to do I take MK808 circuit board from housing and connect it, and from then I have no more problems with Wifi drop down.
About antena gnd conection, I came to the conclusion that it is better if the GND is conected. The signal is increased from 77% to 92%(71dB to 61dB)
I hope this helps to somebody else too.
jockyw2001
Re: How I solved problem with Wifi drop down
Postby jockyw2001 » Tue Feb 19, 2013 8:57 am
Hi, your photos show an external antenna, but in your text you only wrote you removed the housing. Is that external antenna needed or not?
Can you also post a photo with the antenna soldering points in case the external antenna is needed? Thx!
solorajder
Postby solorajder » Wed Feb 20, 2013 7:46 am
jockyw2001 wrote:Hi, your photos show an external antenna, but in your text you only wrote you removed the housing. Is that external antenna needed or not?
Yes, I desolder both original antennas and solder one external antenna(from PC Wi-Fi card).
Without housing works great.
jockyw2001
Postby jockyw2001 » Wed Feb 20, 2013 7:56 am
Thank you! I will try the same and will report in this thread.
ilearner3
Postby ilearner3 » Thu Feb 21, 2013 9:30 am
Due to these two flat antennas in MK808/MK808b, you should set the channel around 6, they works poor on channel 9-14.
I'd tested on my tab 10.1 and mobile phone, both worked terrible at channel 10-13, and my new bought mobile phone even don't have channel 12-14! But both of them worked great at channel 6. At channel 13, I placed my tab10.1 on the wifi router, My tab10.1 get -7dbi, but the transfer rate is even worse than 5M away from the router -5x dbi, terrible, it's 2xMb/s from 3xMb/s, If I choose channel 6, place tab10.1 on the router, it's 50Mb/s!
If somebody nearby also use the channel 6, you can.................
simple and destructive. It's all about wifi.
ccs1676
Postby ccs1676 » Sun Feb 24, 2013 12:17 am
ilearner3 wrote:Due to these two flat antennas in MK808/MK808b, you should set the channel around 6, they works poor on channel 9-14.
i'll have to try this. i hope to only solder as a last resort.
