Is this compatible with 4:3 screen res, wired mouse and KB?
Kyunaga
Postby Kyunaga » Thu Feb 14, 2013 3:42 pm
Is the MK808 compatible with 4:3 screen resolutions? I want it to run on my old Dell display that has a resolution of 1280 x 1024. It only accepts VGA but I have a HDMI > DVI adapter and a DVI > VGA adapter.
The second question is if the MK808 works with a wired mouse and keyboard if I have a hub?
Thanks in advance!
ccs1676
Re: Is this compatible with 4:3 screen res, wired mouse and
Postby ccs1676 » Thu Feb 14, 2013 6:45 pm
can't say for sure if the vga-dvi-hdmi would work, but i don't see why not. ditto for the 4:3 aspect ratio, although things might look squished? just a guess. and yes i can confirm a wired mouse and kb work fine when plugged into a hub :)
MrFX
Postby MrFX » Fri Feb 15, 2013 7:34 am
for VGA you need a real converter, not just an adaptor...
You have to convert the digital output to an analog signal.
The aspect ratio depends on the converter.
Best wishes,
MrFX
t3l3m4k0
Postby t3l3m4k0 » Fri Feb 15, 2013 3:47 pm
I have a active hdmi-to-vga converter, I connected mk808 to a 4:3, 1280x1024, 17" monitor whit this device, and it works ok excepts form factor error, at 720x576.
