Wifi cannot be turnned on. It goes to off immediately.
brightlight
Postby brightlight » Thu Dec 27, 2012 7:17 am
in my MK808 mini TV, I cannot turn on the wifi at all. It immediately goes back to off. I tried with 2 different firmwares and the problem remains on both. Can anyone help me to resolve this problem?
Thanks in advance.
lukesan
Re: Wifi cannot be turnned on. It goes to off immediately.
Postby lukesan » Thu Dec 27, 2012 8:13 am
I had that yesterday after I flashed a friend of mine his minix. I rebooted and everything was ok after.
brightlight
Postby brightlight » Thu Dec 27, 2012 8:35 am
I tried flashing with 3 different firmware and are having the same problem. Can you please give me the url for the firmware you have flashes so that I can try with that one.
baffone001
Postby baffone001 » Thu Dec 27, 2012 4:19 pm
Check if you flasdhed a mk808 firmware on a mk808b firmware. Because this happened to me. Solved going back to stock-root firmware.
brightlight
Postby brightlight » Thu Dec 27, 2012 11:03 pm
baffone001 wrote:Check if you flasdhed a mk808 firmware on a mk808b firmware. Because this happened to me. Solved going back to stock-root firmware.
Thankyou... Thankyou... Thankyou.
You are absolutely correct. I have ordered for MK808 and they have sent me MK808B. I could not know this from the package as it says MK808. It is mentioned only in the price sticker. When I tried the item for the first time, it did not even work... just stuck up with GoogleTV display. The geekbuying support sent me a link to upgrade the firmware. With that firmware wifi totally failed to turn on. I did try with 3 other firmwares with no luck.
After seeing your reply, I double checked the item package and made sure it is MK808B. I then downloaded the firmware from http://blog.geekbuying.com/index.php/20 ... -download/.
With this firmware, miniTV works fine. Thanks once again
baffone001
Postby baffone001 » Fri Dec 28, 2012 12:20 pm
You're very welcome.
I've got MK808B like you, I installed the stock one (like you did) but picked up the root one. I'm having other kind of problem, please check my other threadto see if you're experiencing it too.
Let's hope someone adapts a ICS or Finn. firmware to our MK808B, it shouldn't be hard to do but I don't have any idea about it.
Cheers.
cregeling
Postby cregeling » Tue Jan 15, 2013 6:22 am
http://ql.nu/mk808
your solution, you might have a clone
