Ubuntu 14.10 Wifi Driver!
Postby deadhp1 » Thu Jan 15, 2015 4:19 am
Found a wifi driver that works for the Meegopad-T01 in Ubuntu 14.10.
You'll need a network connection or download the tar backup)
mkdir ~/extras
cd ~/extras
sudo apt-get install git
git clone https://github.com/hadess/rtl8723as
cd rtl8723as
make
sudo make install
sudo modprobe r8723bs
Wifi is now up and running!
Since I'm doing a lot of testing, I put the source in a tar file and copied it over to the livecd. Now when I'm testing a fresh install I copy and extract it to compile it.
tar backup of git for offline installation:
meegopad_wifi.tar
Raymond Day
Re: Ubuntu 14.10 Wifi Driver!
Postby Raymond Day » Thu Jan 22, 2015 1:20 pm
Do you have a link to the live CD you run this from? I got a live CD 14.04 but it did not boot even when I put it on a USB flash drive. I had it on a USB DVD drive.
-Raymond Day
Postby deadhp1 » Fri Jan 23, 2015 10:21 am
I've made an custom Ubuntu 14.10 livecd with this already installed.
viewtopic.php?f=574&t=79720
I don't recommend compiling this on Ubuntu 14.04. I ran into some errors, so I stuck with 14.10.
As for booting a normal Ubuntu 14.10 x64 livecd off the flash drive, you need to add bootia32.efi to the boot directory on the livecd.
The main issue with the Intel Z37xx chips is that they have a 32-bit bootloader with a 64-bit processor.
Details here:
viewtopic.php?f=574&t=79717
slackstick
Postby slackstick » Mon Feb 23, 2015 4:01 pm
Is this driver stable? I have a Pipo X7 and after some minutes one process of the WLAN driver consumes 100% load of one CPU, WLAN is down and even the system does not shut down any more. No problem with USB stick and rt2800usb driver.
Canondigiphoto
MeeGo Pad To1 drivers
Postby Canondigiphoto » Sun May 03, 2015 11:15 am
Where can I get MeeGo Pad To1 drivers? I reinstalled Windows and my WiFi and USB 2.0 Ethernet not connecting to network. Do anyone have backup of drivers? Thanks.
Canondigiphoto
Postby Canondigiphoto » Sun May 03, 2015 1:34 pm
I got it fixed!!! :D
jacky501
Postby jacky501 » Thu Jun 11, 2015 3:28 pm
How to install wifi driver from offline with your tar backup ..........
