New Stock Firmware ZP990+ 20140222-093228
Postby deadhp1 » Mon Mar 03, 2014 11:02 am
New Stock Firmware update for the ZP990+ MTK6592
Details:
Not Rooted.
Android Version:
4.2.2
Baseband Version:
MOLY.WR8.W1315.MD.WG.MP.V21.P15, 2014/01/20 11:28
Kernel Version:
3.4.39 user@linux-user #1 Fri Feb 21 15:52:38 CST 2014
Build Number:
ZP990+ 2014022-093228
Download from the google drive mirror:
http://adf.ly/eJchx
Flash with SP Flash Tool.
As usual avoid flashing the preloader!
poechang
Re: New Stock Firmware ZP990+ 20140222-093228
Postby poechang » Wed Mar 05, 2014 8:53 am
To deadhp1......thx many for these firmware. That makes ZP990+ better. ;)
By the way, for incoming call min_math still 11 digits? Kindly asking help for revised the value to be 8 for next issued? Because these firmwares still can not matching with caller ID for some countries.
Anyway, thx so much for every firmware you issued. :lol:
Postby deadhp1 » Thu Mar 06, 2014 8:57 am
Thanks!
Any ideas on how to fix that? I'll look into it too and see if I can fix.
Just received and OTA update on this rom, so I'll be taking it and making a full backup. Expect a new stock firmware tonight!
poechang
Postby poechang » Thu Mar 06, 2014 11:45 am
I try to decompile framework.odex, but seem not work. always got many errors.
and I check with smali/android/telephony/PhoneNumberUtils.smali. Seems not any number shown on ".field static final MIN_MATCH:I" after this work is empty.
Also kindly check XDA post is shown as follows,
http://forum.xda-developers.com/showthr ... ?t=2268120
http://forum.xda-developers.com/showthr ... ?t=2347106
I have used these way to revised others phone from China. It work... but not for ZP990+. I always get many errors information @ decompile and compile process.
thx many... ;) Doing wish ZP990+ running well......
poechang
Postby poechang » Thu Mar 06, 2014 12:34 pm
BTW.... any Xposed Framework + GravityBox can be running well @ ZP990+? I try to install many versions, but always jam at boot screen.
GravityBox APK I got from ZP990+ Hybrid V0.2a Firmware. thx :mrgreen:
Postby deadhp1 » Sun Mar 09, 2014 2:01 pm
Yeah gravitybox/xposed framework seem to only work on the Hybrid V0.2 series.
I think I ported 7 roms to the ZP990+ and ZP980+ before I found one that wouldn't reboot or crash.
As for the contacts matching, I've seen a couple of different fixes that might work.
One involves editing the build.prop by adding this:
ro.init.phonenumber_match=9
(Change the Number to whatever you were looking for)
You may need to backup and restore your contacts after doing this.
poechang
Postby poechang » Mon Mar 10, 2014 2:40 am
Dear deadhp1...thx many it works.....
