Easily Root Zopo ZP990+
Zopo has upgraded the original ZP990 to the 1.7Ghz MTK6592 8-core soc.
It also features a 5.95" FHD display, 2GB of RAM, and 32GB of flash
Postby deadhp1 » Wed Feb 19, 2014 12:43 pm
This has to be the easiest way to root the ZP990+!
Steps:
1)On the Zp990+ go into Settings-->Security--->Enable Unknown Sources
2)Download and install Framaroot-1.9.1 from http://forum.xda-developers.com/showthr ... ?t=2130276
or
Framaroot-1.9.1.apk
3)Launch Framaroot, Select the "Barahir" option and reboot
4)Enjoy your rooted zp990+
concrete_jungle
Re: Easily Root Zopo ZP990+
Postby concrete_jungle » Mon Apr 14, 2014 10:10 am
u lucky, mine said 'your device seems not vulnerable to exploit included in framaroot.......
concrete_jungle
Postby concrete_jungle » Mon Apr 14, 2014 10:20 am
sorry i had old frama version but now than i used the 1.9.1 framaroot i get this message: try an other exploit in the list and no one is working...
Postby deadhp1 » Mon Apr 14, 2014 12:56 pm
If your running one of the last 2 ota updates then root is built in.
To enable it just go to Settings----->Security------>Superuser and turn it on.
For full shell root(like for adb) you'll still need to patch the boot.img
Return to “Zopo ZP990+”
