How to Root Tronsmart Vega S89 4.4.2
Android Set-top box featuring the quad core Amlogic S802 chipset with 2GB of ram and 16GB internal flash.
Postby deadhp1 » Tue Apr 15, 2014 4:19 pm
I am not responsible for anything that happens to your device! Use at your own risk!!!!
If you are already rooted, don't bother with this method. It probably won't work.
There are already a few methods to root the Tronsmart Vega S89.
http://blog.geekbuying.com/index.php/20 ... 02TRVezdnc
I prefer to have SuperSU with root instead of other programs. So I chose an alternative method using the stock recovery.
This method comes from Rozak originally for the Onda v975m tablet. http://www.slatedroid.com/topic/103449- ... ndroid-44/
Here are easy instructions on how to root your S89 with a microsd card.
Prep:
1)Download Tronsmart_S89_4.4.2_Root_SU-1.93.rar and extract it.
2)Place these two files on a fat32 formatted microsd card.
-factory_update_param.aml
-Tronsmart_S89_4.4.2_Root_SU-1.93.zip
Root Steps:
1)Turn off Tronsmart S89
2)Insert microsd card to S89
3)Using a Toothpick press and hold the hidden reset button(inside av port) and the power button until Green Android appears.
4)Installation will complete and reboot automatically.
georgetan
Re: How to Root Tronsmart Vega S89 4.4.2
Postby georgetan » Fri Apr 18, 2014 1:10 pm
Thanks! It work for me. :D
Tim3Ds
Postby Tim3Ds » Mon Apr 21, 2014 12:16 pm
I have found an interesting feature of the update software.
It lets you select a file to update from and it works to root with the zip file for rooting.
raff
Postby raff » Thu Apr 09, 2015 11:16 am
Thank you very much! i was looking for this root for a long time!
criscol64
Postby criscol64 » Fri Jan 15, 2016 8:39 pm
Cool
Return to “Tronsmart Vega S89”
