ZP980 flip case works on Zp980+
Headsets, Cases, Chargers, USB Devices, etc for the ZP980+
Postby deadhp1 » Sun Jan 26, 2014 2:49 pm
I purchased a flip case made for the original Zopo ZP980/Zopo C2 and it works great for the ZP980+. The body of the phone is basically the same design.
http://www.geekbuying.com/item/Protecti ... 16112.html
The case is a perfect fit. The back provides a textured surface, and has a slight hump on the left side where the cover attaches.
The bump and texture add a nice grip feeling to the ZP980+.
It's simple to install by removing the stock battery door and clipping the flip cover into place.
I've got some other cases on order and will add them to this section as they arrive.
Also on order is a battery from the ZP980, I'll test it to make sure it works in the ZP980+.
