Keyboards Mouse
junkaccnt64
Keyboards Mouse
Postby junkaccnt64 » Sat Dec 29, 2012 7:56 pm
Here are my adventures.
When booting in to recovery, my Das Keyboard Pro (1st gen) w/ 2 port usb hub built in did not work.
When booting in to recovery, my Microsoft Optical Mouse Blue did not work.
When booting in to recovery, my Dell Soft Keys keyboard worked.
When booting in to any revision of 4.0.4, my Das Keyboard Pro worked and I was able to plug an 8GB Mushkin USB drive and Microsoft Optical Blue mouse in to the 2 addition USB ports provided by the keyboard.
The Dell keyboard also works.
I was successfully able to pair my Apple BT Mighty Mouse with 4.0.4 but it did not understand clicks or scrolls, so it was just a floating pointer.
I have not been able to pair my Apple BT keyboard A1255, i receive the error unable to communicate.
I only power via the wall adapter.
newhousik
Re: Odp: Keyboards Mouse
Postby newhousik » Thu Jan 10, 2013 5:14 pm
Logitech K260 - Work
Wysyłane z mojego GK802 za pomocą Tapatalk 2
Deidak
Re: Keyboards Mouse
Postby Deidak » Tue Jan 15, 2013 6:41 am
I have a logitech K400 that works well with the GK802.
I do have an issue with the input languagfe so: Allthough is set the system language as well of the keyboard language to GERMAN - Android the device is still using the english layout.
Any ideas on how to solve that?
Best
Stefan
sn0w
Re: AW: Keyboards Mouse
Postby sn0w » Tue Jan 15, 2013 3:42 pm
Same like with any other sticks... buy external keyboard helper pro and problem is gone..ß
Gesendet von meinem GT-P7500 mit Tapatalk 2
rkelly
Re: Keyboards Mouse
Postby rkelly » Thu Jan 17, 2013 2:39 pm
My Trust Thinity keyboard with touchpad works on the desktop.
It also works in recovery mode.
Oddly enough the audio mute button does not work, it did work on my Tizzbird F30 which runs Gingerbread.
GK802 (Presumably 1st version)
Acceptu
Re: Keyboards Mouse
Postby Acceptu » Fri Jan 25, 2013 9:37 pm
microsoft wireless keyboard + mouse 800 keyboard types but every 2-3 charters it repeats till back space is press, mouse does not work
trust mi-2150 wired usb mouse works
cherry ku 0556 wired usb mouse works
gebnix
Re: Keyboards Mouse
Postby gebnix » Sat Jan 26, 2013 9:04 am
I'm using this ipazzport wireless keyboard/touchpad combo whis is working fine but it's working range could be better ;) :
http://www.amazon.de/Wireless-Handheld-schnurlos-Kabellose-Handheld-Mini-Tastatur/dp/B00860KA2O/ref=sr_1_1?ie=UTF8&qid=1359204869&sr=8-1
I tried to use this general keys Combo from Pearl but it was not recognized by the GK802 with Android (i will try with linux later, too) :
http://www.pearl.de/a-PX2570-1002.shtml
To get the german layout working, i'm using the "external keyboard helper" from playstore :
https://play.google.com/store/apps/details?id=com.apedroid.hwkeyboardhelper
There is a demo version, too.
regards
gebnix
mszl
Re: Keyboards Mouse
Postby mszl » Sun Jan 27, 2013 5:18 pm
HI!
Anybody try to use ps3 or xbox game controller???
claxx
Re: Keyboards Mouse
Postby claxx » Mon Feb 04, 2013 5:29 pm
I have been using my Dinovo mini by Logitech.
features built in mouse touch-pad.
Back-lit keyboard.
Media buttons. volume up/down.
Work with built-in Bluetooth on the mx1 and gk802 or with dongle on the mx1 only .
Can be switched to ps3 mode.
can power on/off my imito mx1 and zealz gk802.
some function keys don't work, but overall the experience is excellent especially with xbmc.
and its very Compact.
jonsey
Re: Keyboards Mouse
Postby jonsey » Thu Feb 14, 2013 9:44 am
just received my Logitech K700 keyboard...im lovin' it! :twisted:
Following the link from where i've bought...
http://www.ebay.it/itm/150859972564?ssP ... 841wt_1186
Ordered 15 genuary,received today...no dogane taxes.22 euros shipped!I LOVE HK sellers! 8-)
guydroid208
Microsoft Wireless 2000 combo
Postby guydroid208 » Thu Feb 21, 2013 3:31 pm
I have the Microsoft Wireless 2000 Desktop. This includes the keyboard and mouse. It is connected via (1) oversized dongle.
Utilizing the rooted firmware (Android version 4.0.4), you can get either the mouse to work or the keyboard, but not both.
Here is what I discovered:
1) You need to install the USB dongle with the GK802 POWERED DOWN.
2) Power up the GK802 with the mouse POWERED ON, it will detect the mouse. But the only keyboard keys that work is the home key and the calculator key.
3) Power up the GK802 with the mouse POWERED OFF and plunk away on any key on the keyboard while it is booting. The keyboard will be detected, but the mouse will not.
4) Power up the GK802 with the mouse POWERED ON and plunk away on any key on the keyboard. You will see the mouse get detected, for a split second the keyboard does as well, then whatever key you were pressing gets infinitely repeated until you remove the dongle. Note that this combo works perfectly on the iMito MX1
guydroid208
Microsoft Bluetooth Keyboard 6000
Postby guydroid208 » Thu Feb 21, 2013 3:33 pm
Microsoft Bluetooth Keyboard 6000 will pair with GK802, but after a couple of minutes disconnects. Only way to reconnect is to unpair keyboard and rediscover. Keyboard works perfectly with iMito MX1. Probably a firmware bug in ght GK802?
rstirling
Re: Keyboards Mouse
Postby rstirling » Sat Mar 02, 2013 8:46 pm
Acceptu wrote:microsoft wireless keyboard + mouse 800 keyboard types but every 2-3 charters it repeats till back space is press, mouse does not work
I think this device does not work properly with Microsoft input devices... My results are:
Microsoft Wireless Keyboard V3.0 - OK;
Microsoft Wireless Mouse 5000 - Works, but acts weird (hangs and continue);
Microsoft Wireless Mobile Mouse 3500 - Works, but acts weird (hangs and continue);
Very cheap USB Keyboard - OK.
