Serial Port!
Serial Port!
Postby deadhp1 » Sat Dec 15, 2012 7:35 am
The GK802 has solder points for 3.3v serial access.
I used a FTDI 3.3v USB to serial breakout from sparkfun to access it.
https://www.sparkfun.com/products/9873
There are 3 wires that need to be connected.
I connected the RX(GK802) to the TX(usb serial module) and the TX(GK802) to the RX(usb serial module).
The GND is the last wire needed to make the connection.
I had a more elegant solution, but the headers I purchased were slightly too big for the holes.
For now I've got the cable running out the same end as the HDMI port with the tiny cover removed.
I setup minicom to run on /dev/ttyUSB0 at 115200 8n1 with no soft/hard.
I'm now able to get serial output of the uboot, kernel, and console.
The uboot that's currently installed can't be interrupted because it has a bootdelay=0.
I've hexedited the original uboot to have bootdelay=5 and flashed it back to my GK802's internal sd card.
Now I can interrupt the uboot and read the environment using printenv.
It's a pretty big step so far.
I'll be posting up logs in the development section.
jonsey
Re: Serial Port!
Postby jonsey » Sat Dec 15, 2012 1:11 pm
You rocks man! :D
I've just ordered also a GK802 (few days and receive the Hi802 also ;) )
hyperjm
Re: Serial Port!
Postby hyperjm » Sat Dec 15, 2012 9:03 pm
ah so that red wire was the bluetooth antenna! should've taken a closer look. this is awesome. thanks!
