Damaged while opening the GK?
Hanno96
Postby Hanno96 » Thu Jan 10, 2013 5:23 pm
I opened my brandnew GK in order to replace the built in SD card, and found a light green cable lose on one side. Do you know where it shoud be connected to? One end is soldered at the edge of the board, close to a quartz and the Ext SD slot.
Your help is highly appreciated, since I really felt in love with this device. Thanks!
Hanno96
pellemando
Re: Damaged while opening the GK?
Postby pellemando » Thu Jan 10, 2013 6:10 pm
it is not like this then: viewtopic.php?f=50&t=1220
Think the color of the cable can be different
Hanno96
Postby Hanno96 » Fri Jan 11, 2013 5:37 pm
Yes seems that I have not read carefully enough the blog... Thanks for the advise.
I am wondering about the gain of this "antenna" though. The black cable is a mini coaxial cable linking to a planar antenna. I would believe that is the WLAN antenna (certainly more important), while the lose cable might be the blutooth antenna.
