GK802 Rooted and Play Store Fixed Updates!
justix
Re: GK802 Rooted and Play Store Fixed Updates!
Postby justix » Mon Jan 21, 2013 7:36 am
deadhp1 wrote:01/20/2013
New update based on the official 1.65.4 from Geekbuying.
It's been rooted and play store fixed.
Some changes:
-Compatible with both production models
-Working wifi and bluetooth
-NTFS support
-Working recovery/reset button
Version 1.65.4
http://adf.ly/HeNjx
12/29/2012
I've modified the rooted and play store fixed 1.65.3 image with 2 fixes:
-added external sd write fix
-changed mousepointer
Big thanks to fxpilot
Download "rooted_fixed_RT-M500A_V1.65.3b.zip" from ultramegabit.com
http://ultramegabit.com/file/details/D6gahtAPtqw
Or Download "rooted_fixed_RT-M500A_V1.65.3b.zip" from the Google Drive mirror.
http://adf.ly/EY7KP
12/20/2012
I've modified the most current update for the GK802 provided by Geekbuying.
It now includes root and Play Store fixes!
Based on update 1.65.3
Download "rooted_fixed_RT-M500A_V1.65.3.zip" from ultramegabit.com
http://ultramegabit.com/file/details/4j2F_Htgy9k
Or Download "rooted_fixed_RT-M500A_V1.65.3.zip" from the Google Drive mirror.
http://adf.ly/EY7KP
Hi I'm on Stock Firmware 1.65.3 and never update it before, which one is the one I really need? differences between the stock update and the rooted_fixed one? Thank u
kmac21
Postby kmac21 » Mon Jan 21, 2013 12:33 pm
getting md5 checksum errors with both system.img and boot.img files with 20th of Jan update, have downloaded twice with same result. Can anyone confirm if working
GameOver69
Postby GameOver69 » Mon Jan 21, 2013 3:39 pm
hi, is there a way to boot into recovery from within the rom itself, like how CynogenMod has in their roms? my reset button is jacked :( thanks.
eclsnowman
Postby eclsnowman » Mon Jan 21, 2013 4:47 pm
Factory reset will take you there.
Sent from my Galaxy Nexus using Tapatalk 2
Ongth
Postby Ongth » Mon Jan 21, 2013 8:00 pm
I just updated last night, I can confirm that I don't need to repartition using gparted and no need to do factory reset, able to retain all my setting after update.
kmac21
Postby kmac21 » Mon Jan 21, 2013 8:49 pm
eventally after third download all ok, can confirm no need to reset, bt working
eclsnowman
Postby eclsnowman » Mon Jan 21, 2013 9:09 pm
FYI: Factory reset comment referenced how to get to recovery with a broken reset switch.
tdp252
Postby tdp252 » Mon Jan 21, 2013 9:22 pm
thanks, the latest update fixed my major issues:
- couldn't boot into recovery mode
- locking at initial screen with "preparing ssd"
- random wifi dropouts
Everything works well now except video playback is either choppy or has no sound.
So far i'm really enjoying this fast little device and and can't wait to see it improve.
justix
Postby justix » Tue Jan 22, 2013 8:57 am
I can't enter recovery mode, it goes in safe mode instead and the little recovery switch is now gone :evil: PLEASE HELP!
justix
Postby justix » Tue Jan 22, 2013 10:55 am
eclsnowman wrote:FYI: Factory reset comment referenced how to get to recovery with a broken reset switch.
So leaving the SD card with the new firmware and selecting Factory reset should enter recovery?
nelinjo
Postby nelinjo » Tue Jan 22, 2013 11:57 am
This latest fw woke up my device which was laggy as hell. Also noticed less heating applied so i am keeping it. Do you run the device in 720 or 1080? If i change the resolution to 1080 it becomes a bit slower. 720 works awesome.
Thanks deadhp.
viumden
Postby viumden » Tue Jan 22, 2013 12:18 pm
I just updated to 1.65.4 deadhp.1 rooted fw, I guess the bluetooth driver is very bad.
I can connect my Sony Smart Headphone, but the sound is really very choppy and suddenly the connection will drop...
I am considering a rollback...
XtraLarge
Re: AW: GK802 Rooted and Play Store Fixed Updates!
Postby XtraLarge » Tue Jan 22, 2013 6:09 pm
i need help with a problem that i couldn't solve. None of the firmware versions are compatible to the amazon cloud player. If you will play a song from the cloud the song will be downloaded but neven played. If you leave the player he crashes, but after that you can play the downloaded song.
Did anyone have a solution?
Sorry, for my english but i'm not a native speaker :) Thx
fma965
Postby fma965 » Thu Jan 24, 2013 3:26 pm
any chance of adding some extra modules to kernel?
smb/cifs if not already
hfs/ext2/3/4/
xpad
is this likely to happen?
jonsey
Postby jonsey » Fri Jan 25, 2013 8:43 am
To add modules i suppouse you need to recompile kernel,or to push the modulename.ko with adb...
I don't know how to do this,as you,im interest to add modules for an external usb wifi dongle... :roll:
korpenkraxar
Postby korpenkraxar » Fri Jan 25, 2013 3:53 pm
fma965 wrote:any chance of adding some extra modules to kernel?
hfs/ext2/3/4/
xpad
The ext2, ext3 and ext4 filesystems are already compiled into the factory kernel. I've used ext4 myself without any issues whatsoever.
fma965
Postby fma965 » Sat Jan 26, 2013 9:03 pm
hfs/ext2/3/4/
xpad
I can't mount ext2 usb hdd
Via Tapatalk - - My Tutorials
mszl
Postby mszl » Sun Jan 27, 2013 1:55 pm
hfs/ext2/3/4/
xpad
The CIFS support it will be cool!!!! and very usefull
This is one thing that's missing!
korpenkraxar
Postby korpenkraxar » Mon Jan 28, 2013 7:15 pm
fma965 wrote:I can't mount ext2 usb hdd
Weird. I've used EzyMount (available in Play Store) to mount an ext4 USB-formatted stick attached to my USB-hub.
son
Postby son » Sun Feb 03, 2013 6:49 pm
should NTFS work now ot of the box? For it says "Empty SD Card" - Mounting with USB OTG Helper works!
