GK802 Rooted and Play Store Fixed Updates!
sweetyka27
Re: GK802 Rooted and Play Store Fixed Updates!
Postby sweetyka27 » Fri Feb 08, 2013 12:07 pm
[quote="deadhp1"]01/20/2013
New update based on the official 1.65.4 from Geekbuying.
It's been rooted and play store fixed.
Some changes:
-Compatible with both production models
-Working wifi and bluetooth
-NTFS support
-Working recovery/reset button
Version 1.65.4
http://adf.ly/HeNjx
HELP ME!!!!!! I TRY TO UPDATE THE NEW FIRMWARE BUT AFTER REBOOTING MY SCREEN FROZE. SO, I DISCONNECT AND OFF AND ON AGAIN. BUT STILL FROZE. SO, PANICKING, I PUSH AGAIN THE RECOVERY BUTTON AND THEN CHOOSE TO RESET TO FACTORY SETTING. IT WIPE OUT ALL THE GK802 EXISTING DATA AND NOW THE SCREEN IS IN BASIC MODE. NOW, I CANNOT USE MY AIR MOUSE TO EXPLORE THE SCREEN AS I USED TOO COZ IT DOES NOT CONNECT ANYMORE WITH MY RC12 KEYBOARD. MAYBE, DURING THE FACTORY RESET, IT WIPE OUT ALL DATA INCLUDING THE AIR MOUSE RIGHT?? SO, PLEASE HELP ME.... ;(
Craxx
Re: AW: GK802 Rooted and Play Store Fixed Updates!
Postby Craxx » Sat Feb 09, 2013 3:11 pm
Flash a full image to sdcard with winimage.
best regards
Craxx :-)
Send from my Nexus 4 with Tapatalk 2 :-D
andersoncg
Postby andersoncg » Mon Feb 11, 2013 7:41 am
Need some help! I'm trying to run the firmware update. But my rc13 mouse or a wired keyboard will not work in the recovery window. I did find that pushing the reset button I can scroll down but I can't find a way to "select" update image files.
fma965
Postby fma965 » Mon Feb 11, 2013 8:30 am
andersoncg wrote:Need some help! I'm trying to run the firmware update. But my rc13 mouse or a wired keyboard will not work in the recovery window. I did find that pushing the reset button I can scroll down but I can't find a way to "select" update image files.
plug it ditedtly in to the GK802 usb port
Sent from my R800i using Tapatalk 2
My GK802 Dev-Host Folder (Kernel and uBoot Source)
the_sarge_81
Postby the_sarge_81 » Thu Mar 21, 2013 3:45 am
Thank you so much for your job,
anyway yesterday I updated the GK802, and I found several bugs, I would like to tell you about them so you can work on them if you like.
1) Bluetooth:
- on start up it dosn't pair with the previously paired keybord
- after few minutes of good job, it out of the blue disconnects the keybord
2) Keybord:
- italian keybord dosn't recognize special character, and it uses english special character instead
3) Gmail:
- if I scroll down inside the inbox folder, after few rows it restart the app
4) XBMC
- during a film after few minutes it freezes for 4-5 seconds then it restarts
- during the creating of the library it closed several times
5) I don't know how to upgrade Android to 4.1.1 [actually is not a bug, but I would like to know how to do it :P]
So far I think I said everything.
Waiting for update, i wish you all the best, thank you again for the great job.
sakimotosan
Postby sakimotosan » Thu Mar 28, 2013 4:33 pm
junkaccnt64 wrote:Hello, I am unable to update to this firmware using the method described on the geekbuying blog. I receive an error
"Checking the externel card u-boot file
Failed to mount /extcard (No such file or directory)
Check internal card uboot file...
file error 1
found u-boot-no-padding.bin file!
Checking the external card boot.img file
Check internal card boot.img file...
file error 1
check boot.img error!
Checking the external card system file
Check internal card system file...
file error 1
check system.img file!"
I then rebooted in to "working android" and the card mounted fine.
the files that were copied on to the disk were also still there.
Ive noticed the SD card slot was a little loose in "working android" where I would have to wiggle it to get it mount.
Is it possible thats what these errors are, a loose sdcard reader?
Or maybe something with the card itself.
Its a 16GB card "long" formatted in FAT32.
Any thoughts appreciated.
So far my only gripe is Netlfix (sideloaded 1.88, and 2.20) is not HD but streaming from PLEX or through Bubble uPNP works great.
Did you get this fixed? I tried the same thing today and got the same problem. I tried update from the extsd card option but it didn't seem to do anything.
I want to get the device rooted so I can change configurations to make my xbox 360 controller work with games but I can't at the moment.
If you managed to solve it can you share? :)
Thanks in advance!
riggatrigga
Postby riggatrigga » Fri Mar 29, 2013 8:54 am
If you recently got the gk802 it already came with the newest firmware in these forums explains how to manually root the stick and apply play store fix that's the route I had to take it couldn't update either the standard way 1.54 is still the latest even though the factory promised us 4.1 back in feb
sakimotosan
Postby sakimotosan » Fri Mar 29, 2013 12:49 pm
I got mine last week but need to manually root it, is there a way to do this without using the upgrade image as this does not work for me. If there is any article or tutorial you can point to it would be very much appreciated. I am very much a novice when it comes to linux so the more detailed the better! :)
riggatrigga
Postby riggatrigga » Sat Mar 30, 2013 3:59 pm
viewtopic.php?f=51&t=1113&start=40
those are the instructions I used to get it working
sakimotosan
Postby sakimotosan » Wed Apr 03, 2013 11:37 am
Thanks for this!
Fortunately I didn't need it, on trying to upgrade using a different MicroSD (a 16Gb this time) there was no problem. :o
