One Black wire/cable inside GK802 seems to be disconnected
rrajendran
Postby rrajendran » Tue Jun 04, 2013 5:07 am
I had to open the case to flash the internal SD card as an incorrect flash kept freezing the device. While opening the device, I noticed that there were 2 black cables. The first wire was attached to the board on one end but the other end was not connected to anything. The 2nd wire had one end on the board and the other taped to the case. My question is: is the free end of the first wire supposed to be connected to anything? I am concerned that the wire came off when I opened the case.
thanks.
rimakus
Re: One Black wire/cable inside GK802 seems to be disconnect
Postby rimakus » Tue Jun 04, 2013 5:38 am
First one is Bluetooth "antenna". Don't worry about it. It does not connect anywhere. Second one is flat WiFi antenna.
rrajendran
Postby rrajendran » Sat Jun 08, 2013 1:57 pm
thanks!
