Samba Server Apps Wont Work! Is This Just Me?
fma965
Postby fma965 » Sun Feb 10, 2013 2:38 pm
Can any 1 get a SAMBA (SMB) Server running on this?
i have tried SambaDroid, Samba FileServer, and others and none of them work :( ... im using ethernet if that makes any difference although it also didn't work on wifi. Any 1 got any ideas on how to fix it or have they had luck running it?
krasnoff
Re: Samba Server Apps Wont Work! Is This Just Me?
Postby krasnoff » Sun Feb 10, 2013 11:30 pm
I try SambaDroid pro, and have the same problem (with iMito this app work fine).
rsbuffalo
Postby rsbuffalo » Mon Feb 11, 2013 1:07 pm
I use the following (All working on GK802):
1.) Es File Manager (LAN add IPs)
2.) Astro (SMB Modual)
3.) Wifi File Transfer Pro
4.) FileLinx PRO-PC File Share
If you need to steam Media from the GK802. Try some dlna apps.
fma965
Postby fma965 » Mon Feb 11, 2013 8:05 pm
rsbuffalo wrote:I use the following (All working on GK802):
Thanks but not helpful.
1. Client
2. Client
3. Server but doesn't have native drive mounting in windows and is not a STANDARD protocol and XBMC not support it.
4. Server but doesn't have native drive mounting in windows and is not a STANDARD protocol and XBMC not support it.
I am not looking for alternatives i want to get SMB Working... it works on my shitty phone so why not on GK802.
oh and my gk802 runs xbmc and a mysql/webserver i need the final step of SMB and then it's complete... currently using http for file access but would prefer SMB aswell.
fma965
Postby fma965 » Mon Feb 11, 2013 8:06 pm
krasnoff wrote:I try SambaDroid pro, and have the same problem (with iMito this app work fine).
Yeah work with my shitty phone to.
fma965
Postby fma965 » Thu Feb 14, 2013 9:12 pm
ok well i have concluded that SambaDroid does not work on ICS
SamabaFilesharing does not work on JB
SambaDroid does not work on ICS/GB
However SambaFilesharing does work on our GK802 :)
https://market.android.com/details?id=c ... resh.samba
Works perfect, developer version is on XDA allows customizing the smb.conf manually.
grindy
Postby grindy » Fri Feb 15, 2013 2:58 pm
Anyone tried cifs manager? that usually does the trick for me and it works great with XBMC and mxplayer.
fma965
Postby fma965 » Fri Feb 15, 2013 8:09 pm
grindy wrote:Anyone tried cifs manager? that usually does the trick for me and it works great with XBMC and mxplayer.
Please read the thread, i clearly want a Server not a Client.
