Wifi Broken/Coocked?
jonsey
Postby jonsey » Mon Jan 21, 2013 5:45 am
Hi,i have 2 different device,Hi802 and Gk802.As in the mod section,i've installed an external antenna in the Hi802...all works perfectly.
I leave original the GK802...today,i've updated the pendrive Gk802 to the latest 1.65.4 and done a Factory Reset...all ok in the recovery.I reboot the pendrive and no wifi :shock:
I open the Gk802 and see what in the image below...
WTF IS HAPPENED?!?!?!? :evil: :evil: :evil:
The chip REALTEK appears coocked!!!! :o :evil: :evil:
PLEASE HELP! :|
riggatrigga
Re: Wifi Broken/Coocked?
Postby riggatrigga » Mon Jan 21, 2013 6:52 pm
looks like it shorted out somehow not good at all in my opinion don't think u can fix it but maybe someone here knows how
lefizz
Postby lefizz » Mon Jan 21, 2013 7:24 pm
That red wire floating about could be the culprit.
Sent from my ZP900 using Tapatalk 2
jonsey
Postby jonsey » Tue Jan 22, 2013 4:25 am
The red cable is the BT antenna...so you think that the red cable mace a short curcuit?!??! :roll: :roll: :roll:
I don't think it was the problem...
Imagine that also the tape witch cover the flat antenna inside the stick has a hole burned from the wifi antenna -.-' :evil:
Return to “GK802”
