gk802 freezing
claxx
gk802 freezing
Postby claxx » Sun Jan 20, 2013 5:54 pm
Any others experiencing device freezing after reboot?
I flashed my stick with rooted_fixed_1.65.3b_FULL_IMAGE.rar.
now after reboots my USB mouse freezes and the device becomes unresponsive.
any ideas!
docwhoo
Re: gk802 freezing
Postby docwhoo » Sun Jan 20, 2013 7:03 pm
exactly the same probleme ...
i try to restore many firmware!!!!!! but the same result freeze :/
claxx
Re: gk802 freezing
Postby claxx » Sun Jan 20, 2013 9:33 pm
UPDATE
just DD a 16g class 10 sdcard with the latest full image http://www.armtvtech.com/armtvtechforum/viewtopic.php?f=51&t=1113 .
Version 1.65.4
If interested, the dd command sudo dd if=PATH TO/rooted_fixed_rt-M500a_v1.65.4_20130118a_updated_FULL_IMAGE.dd bs=4096 | pv
s 16G | sudo dd bs=4096 of=/dev/mmcblk0
Used Gparted to maximize the last partition.
and now the freezing has stopped.
now some more testing
thank you for the image deadhp1
Re: gk802 freezing
Postby deadhp1 » Sun Jan 20, 2013 9:35 pm
You guys may have the 2nd production run GK802 with slightly different wifi. It's still the same chipset, but older firmwares cause a crash.
I've uploaded a new firmware to the full images thread that is compatible with both 1st and 2nd generation GK802.
It also adds NTFS support and fixes the recovery issue.
Check it out in the firmwares section!
Future updates should always be compatible.
edit: you beat me to it claxx! I was just writing about it lol
