Leave it running or unplug it?
VegasGuy
Postby VegasGuy » Wed Nov 28, 2012 7:02 pm
Do you leave your UG802 running or do you unplug it when not using it? I'm in the leave it running camp. Also, is there a another way to power it off without pulling the plug?
xr4man
Re: Leave it running or unplug it?
Postby xr4man » Thu Nov 29, 2012 10:34 am
i just leave it running. it pulls less power than my pc in sleep mode, so why not?
VegasGuy
Postby VegasGuy » Fri Nov 30, 2012 12:59 pm
xr4man wrote:i just leave it running. it pulls less power than my pc in sleep mode, so why not?
I should have been clearer on my reason for asking. I agree with your answer cost is not an issue. My main reason for asking about leaving it running or looking for a software power down solution is the risk of file corruption. Pulling the plug does not seem like a 100% harmless method of powering down when needed.
xr4man
Postby xr4man » Fri Nov 30, 2012 2:22 pm
that is true also.
mainly i leave mine on all the time because electronics generally like to stay in a steady state. if they are powered up or in standby, all the circuitry is staying warm and fuzzy. powering on and off regularly causes component degradation. of course by the time you'd see the effect of it, you'd have upgraded due to these things being way obsolete then.
dany79ing
Postby dany79ing » Thu Jan 10, 2013 9:00 am
I have the same question, what is better plug or unplug the power supply because it has power off button?
