Google Play Store Fix for UG802
Postby deadhp1 » Thu Sep 20, 2012 5:50 pm
Fixing Google Play Store.
I spent a while searching, but I found others who had this problem. That led me to the instructions from Compu_Guy which is found in the link below.
http://www.androidtablets.net/forum/syl ... post164159
Our TelephonyManager.smali files is a bit different so I’ve simply removed 2 steps and changed the number we’re looking to replace.
Keep in mind that this could send you on a boot loop, brick your device, cause you to worship the sun, eat earthworms and I won’t be held responsible.
First off you need to be rooted and your system mounted as R/W. Also if you’re on windows you will have to install JRE 1.6 and add that to path so you can run apktool.(there are instructions in the apktool wiki)
“Here are the steps that I followed.
1) Download apktool from here:
http://code.google.com/p/android-apktool/
I used the Windows version, so there are two files that you need to download. Load both of those into a directory.
2) Grab your framework.jar file from you tablet. This is located in /system/framework
3) Copy this file to the same folder that you put the apktool
4) Open a command prompt and run apktool with this command: apktool d framework.jar
5) This creates a folder called framework.jar.out that contains the smali files. Open this folder and go to smali/android/telephony
6) Open TelephonyManger.smali with a good text editor. On Windows, I use Notepad++.
7) Look for the string of 46002. I just replaced this with 310260. In my case, there are two instances of it. 8)When you are done, save the file.
9) What I then did was renamed the framework.jar file to framework-old.jar
10) Now from your command prompt run apktool b framework.jar.out
This will recompile a new jar file for you. The file will be placed in framework.jar.out/dist.
11) Now open this file with a good zip editor (IZarc, 7zip, etc). There will be a classes.dex file.
12) If you open your original one, you will see there is also a META-INF folder and preloaded-classes file. I copied these out of the original and into the new file.
13) Copy the new framework.jar file on your tablet and replace the existing one.(Make sure to check the permissions on the new framework.jar)
14) Restart!”
You may want to clear Play Store’s cache and data before you load it after doing this.
I’ve uploaded my modified framework.jar here
Firmware 7/13 http://www4.zippyshare.com/v/81293609/file.html
Firmware 9/03 http://www8.zippyshare.com/v/32689528/file.html
I have no idea if it will work in newer firmwares, so when in doubt do the steps above.
Btw the number 46002 is for China Mobile, the number 310260 is for T-Mobile US.
Re: Google Play Store Fix for UG802
Postby rayjr13 » Wed Sep 26, 2012 12:33 pm
I planned on using the VZW code from the wikipedia list. not sure it will make a difference at this point there used to be more apps that were exclusive VZW. See any issues with doing that. What about making the VW mod to the Firmwares you've upped that have the Tmob code baked in?
rayjr13
Postby deadhp1 » Wed Sep 26, 2012 2:39 pm
What's the vzw code you want to use?
It's easily changed using the same steps here.
If you want I'll do it for you.
Postby rayjr13 » Fri Sep 28, 2012 4:51 pm
MCC 310
MNC Carrier Note
012 Verizon Wireless No longer a GSM provider. Former entity Airtouch Cellular was planning on using GSM before the creation of Verizon. Verizon is also looking at the LTE technology for their 4G network, which is in the GSM family. May also be used in "International" phones with additional GSM equipment. The LTE network uses the 311-480 MNC-MCC below for the SIM cards while the network uses 310-012. (See 311 section).
so I gathered
310012
rayjr13
Postby deadhp1 » Sat Sep 29, 2012 9:28 am
which firmware do you need the vzw framework.jar for?
Postby rayjr13 » Sat Sep 29, 2012 12:37 pm
Lol dunno still waiting on the thing to show up. Any suggestions?
rayjr13
Postby bravomail » Tue Oct 02, 2012 10:55 am
Try putting/replacing following into /system/build.prop:
ro.product.model=GT-N7000
ro.product.brand=samsung
ro.product.name=GT-N7000
ro.product.device=GT-N7000
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=samsung
ro.product.locale.language=en
ro.product.locale.region=GB
ro.board.platform=exynos4
ro.build.product=GT-N7000
ro.build.description=GT-N7000-user 4.0.4 IMM76D XXLRT release-keys
ro.build.fingerprint=samsung/GT-N7000/GT-N7000:4.0.4/IMM76D/XXLRT:user/release-keys
ro.com.google.clientidbase=android-samsung
#Enable GPU Acceleration
debug.sf.hw=1
video.accelerate.hw=1
debug.performance.tuning=1
persist.sys.composition.type=gpu
Galaxy Note N7000 has Cortex A9 CPU with Mali GPU - just like UG802 RK3066. And its display resolution is 1280x720. So it's a good match.
bravomail
Postby usiek » Sun Oct 07, 2012 3:54 pm
deadhp1 Your upload for firmware 7/13 works great!
many thanks!
usiek
Postby xr4man » Tue Oct 09, 2012 10:20 am
ok, i just broke my sh!t, lol.
i'm pretty sure i followed the directions to the letter with the exception of trying to use the vz code instead of the t-mobile code.
i now have the message "unfortunately, the process com.android.phone has stopped"
will this require me to open it up and short out the two pads to get into the flash mode to reflash it or is there another option?
oh yeah, i had flashed the finless 1.4 rom and it was all working fine until i tried applying the google store fix.
xr4man
Postby deadhp1 » Tue Oct 09, 2012 10:53 am
are you rooted and able to get into a terminal, or at least get into settings to turn on usb debugging and usb connect to pc?
Next
Return to UG802
