SD Card, Memory Usage and installing Apps to physical SD Car
gamesfrager
Postby gamesfrager » Sat Oct 20, 2012 3:43 pm
I have a question,
Since I got my device, I have been installing apps and removing some, but then I hit a road block, the available internal storage is too low ~200MB !
Question: If I buy a physical SD card and insert it into the available slot; can apps be installed to it? if not, is it possible to move some of the internal SD memory (maybe another 1GB) to internal memory just to give it more breathing room?
I have a HP Touchpad with CM9 installed on t, and there was an update to enable moving 1024 MB from internal SD to internal memory and boosting it it up.
Thanks,
Sinan
Return to “UG802”
