HELP! External Monitor Mode - need a fix...
rubi76
Postby rubi76 » Sat Oct 13, 2012 10:25 am
The UG802 sees the tv connected as an external monitor (as if you would connect your phone to the tv with MHL).
This setup prevents us from using a few apps (HBO GO?) that don't support external monitors.
I basically got this stick just to watch an Italian App which is now locked to external monitors.
I had an MK802 and this would not happen!
Could we maybe install the MK802 software on this?
Any thoughts / solution on this?
Maybe something to change in build prop?
(By the way, I am using Finless room, but I believe this problem is on Stock Software as well).
craleu
Re: HELP! External Monitor Mode - need a fix...
Postby craleu » Sat Oct 13, 2012 11:13 pm
Its because its an HDMI out connection :(
rubi76
Postby rubi76 » Sun Oct 14, 2012 12:39 am
Definitely because it's an hdmi connection..
But is there a way to "fool" the software?
The mk802 did not show it as external connection...
rayjr13
Postby rayjr13 » Mon Oct 15, 2012 8:42 pm
Not sure I want to use this so much any more and I just got it lol. I need a solution for this or IM looking for the next device. /rant seriously I would love this otherwise.
Return to “UG802”
